Home > Forums > OpenFOAM
Laplacian(A*B)
Like Tree4Likes
Old   August 14, 2013, 12:22
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
you could try to implement it implicitly
fvc::laplacian(delta*F,Psat) = fvc::div( delta*F*grad(Psat) )
volVectorField dps = delta * fvc::grad(Psat);
surfaceScalarField dpsf = fvc::interpolate(dps) & mesh.Sf();
then you can view the dps field as a 'convective' change of F due to the Psat gradient
and rewrite it like this
fvc::laplacian(delta*F,Psat) = fvm::div(dpsf, F)
...should work
niklas is offline   Reply With Quote
Old   August 14, 2013, 13:35
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
That's a pitty. But the code of niklas seems to be promissing. Ricardo, I didn't get your approach in total. Could you explain it in a little more detail? Especially the part of the lduAddressing.
Regards
Fabian
immortality likes this.
fabian_roesler is offline   Reply With Quote
Old   August 14, 2013, 14:21
Richard
Ricardo is on a distinguished road
...should work
implementation to solver >> solve (fvm::ddt(dw,F)==fvm::laplacian(lambdaD*Psat,F)+fv m::div(dpsf, F)); doen't works, too
Originally Posted by fabian_roesler View Post
Hi
Regards
Fabian
This is my code, but it I am still working ...
a part of code ...
    float tdelta = 1.0;
    float tdeltaN = 1.0;
    float fdelta = 1.0;
    float fdeltaN = 1.0;
    double relFaktor = 1.0;
    int iter = 0;
    #include "boundaryCalculation.H"
    do
    Tt = T;
    #include "heatParameters.H"
    solve
               fvm::ddt(cap,T)==fvm::laplacian(lambda, T)//+hv*fvc::laplacian(lambdaD, Psat*F)
    T=(relFaktor)*T+(1-relFaktor)*Tt;
    tdeltaN=diffFields(T,Tt);
    #include "saturatedpressure.H"
    #include "moistureParameters.H"
    fvScalarMatrix mat1
          fvm::laplacian(lambdaD,F)
    label Nc = mesh.nCells(); //Total number of cells
    // Diagonal coefficients calculation
        for(label i=0; i<Nc; i++)
          mat1.diag()[i]*=Psat[i];
    //Off-diagonal coefficients calculation
        for(label faceI=0; faceI<mat1.lduAddr().lowerAddr().size(); faceI++)
    mat1.lower()[faceI]*=Psat[mesh.faceOwner()[faceI]];
      mat1.upper()[faceI]*=Psat[mesh.faceNeighbour()[faceI]];
      dimensionedScalar Pa ("Pa",dimensionSet(1,-1,-2,0,0,0,0), 1.0 );
    mat1*=Pa;
    solve
            fvm::ddt(dw,F)==mat1
    //fvm::laplacian(lambdaD*Psat,F)//+fvc::laplacian(dT,T)// //
    F=(relFaktor)*F + (1-relFaktor)*Ft;
    fdeltaN=diffFields(F,Ft);
    #include "w_prepocet.H"
    iter++;
    if (iter==1)
    tdelta=tdeltaN;
    fdelta=fdeltaN;
    if ((tdeltaN>tdelta) || (fdeltaN>fdelta))
    relFaktor=relFaktor/2;
    } while (((tdeltaN>maxDeltaT) || (fdeltaN>maxDeltaH)) && iter < maxIter);
my approach to laplacian(labmbdaD,F*Psat) is in code, maybe for expert it could be ridiculous , but I am working with openFoam and C++ 2 weeks, and this code gives some "expected" values. Other approach gives unstability or doesn't work...
I tried next approach, rewrite partial pressure by gradient of temperature, it seems, that gives similar values like lduaddressing script
I don't know where is problem, I have to check all functions, material parameters and other properties again,...
thanks to all for support and advices
Richard
Ricardo is offline   Reply With Quote
Old   August 14, 2013, 15:11
niklas's Avatar
Niklas Nordin
you REALLY need to be more specific when you say 'it doesnt work'.
Old   August 14, 2013, 15:39
Richard
I was wrong , It works, but obtained values ...
dimensions [0 0 0 0 0 0 0];
internalField nonuniform List<scalar>
4000
-1.35814e-10
4.58031e-11
4.58031e-11
4.58031e-11
4.5803e-11
4.58031e-11
4.58031e-11
4.58031e-11
-1.82592e-10
-1.77054e-12
-2.23032e-11
So it seems (two scheme unstable), that a problem could be somewhere else,
Is right using parameters (lambda), stored as volScalaField and (ununiform field) calculated in each step equation by this way? (fvm::laplacian(lambda,T)) Is it interpreted correctly to scheme or is used average values?
Thanks
Richard
Thread Tools
Trackbacks are On
