Compressible flow solver for density and velocity only |
March 31, 2020, 09:30 |
Ali Shakeri
Rep Power: 5 |
Hi everybody,
I am modelling an isothermal compressible flow. I have constitutive relation for viscosity and equation of state for pressure and temperature is always constant. I am reading the OpenFOAM user guide to find a suitable solver for my problem. I think I should choose one of these solvers:
The problem with all above solvers is that temperature is a mandatory field in all of them. However, I have no equation for temperature. Do I have other options in OpenFOAM to solve a compressible flow with only mass and momentum equations? |
April 1, 2020, 05:12 |
CHEUNG WING KI
Rep Power: 8 |
Compressible flow solver does not solve the temperature directly, instead it solves the energy equation(h or e) then compute the temperature after that.
So temperature B.C. is mandatory in compressible flow while it's not in incompressible flow(only p, U) In addition, only solving mass and momentum conservation equations in compressible flow would not be conserved. |
April 1, 2020, 05:45 |
#3 | |
Ali Shakeri
Rep Power: 5 |
Imagine that temperature is always constant. So, the only variables are density and velocity fields. Therefore, we can write conservation of mass and momentum and we can solve this system by constitutive relations for viscosity and pressure. In my case even the constitutive relations are independent of temperature, so temperature and energy are totally irrelevant for my problem. Therefore, I am looking for a simple isothermal compressible solver. Is there such a solver in OpenFOAM? What I can imagine is that I can use the rhoCentralFoam and put the right hand side of the energy equation to zero (ignore it). However, this means that I will waste some computational power for a variable which I do not have it in my problem. |
April 1, 2020, 07:03 |
CHEUNG WING KI
Rep Power: 8 |
What I am confused is that even though the temperature is at constant does not mean the energy the same. Because the temperature is not just a simple scalar (like solving scalar transport equation), but a scalar determined by internal energy or enthalpy.
As far as I've learnt in fluid dynamics, the energy equation's always activated when the flow has compressibility. If you still intend to do it, you may try rhoPimpleFoam. |
April 1, 2020, 07:34 |
#5 | |
Santiago Lopez Castano
Rep Power: 15 |
To answer your question, no, there isnt such a solver implemented in FOAM. You'll have to write it. Fortunately for you, you just have to base it on rhoPimpleFoam for the flow solver, delete whatever is related to temperature/enthalpy and just add the PDE for density. Such programming effort shouldn't take you long, if you know how to 'fiddle' with FOAM. |
April 1, 2020, 08:42 |
#6 | |
Ali Shakeri
Rep Power: 5 |
Thanks for the response. To elaborate, my problems is solving the hydrodynamic equations for a granular flow. Such flow is compressible but the temperature and energy does not play a role. In my problem, pressure and viscosity are functions of density only. I will follow your suggestion. |
January 3, 2022, 09:54 |
Pengcheng Zhang
Rep Power: 4 |
Hi Ali,
I have the same problem as you. Have you solved the problem yet? I've been trying to simulate the water hammer effect in hydraulic turbine with rhoPimpleFoam(or pimpleFoam?). In my case, the compressibiliy of water needs to be considered and energy equation is superfluous. I would appreciate it if you could give me some advice on how to modify rhoPimpleFoam or any other solutions. Thank you! Last edited by Zane; January 4, 2022 at 04:48. |
compressible flow, density based |
Display Modes | |
Zigzag velocity and pressure with compressible solver | Gerry Kan | OpenFOAM Running, Solving & CFD | 3 | March 7, 2020 13:36 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 06:21 |
Problem with time average tangential velocity in swirl flow. | lakhi | FLUENT | 5 | July 18, 2012 17:28 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 06:36 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
