Foam fatal io error:
Like Tree1Likes
  • 1 Post By wyldckat
Old   November 27, 2010, 05:28
Default Foam fatal io error:
Stephen
basilwatson is on a distinguished road
Hi all
When I try to run my file, I keep getting this error message... though when I check the Polymesh boundary file it all looks ok to me........see below;
Any Ideas to point me in the right direction?
Kind regards Stephen
--> FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 77
Reading /home/s/OpenFoam/incompressible/simpleFoam/enterprise/constant/polyMesh/boundary
found on line 62 the punctuation token ')'
expected either } or EOF
--> FOAM FATAL IO ERROR:
Expected a ')' or a '}' while reading PtrList, found on line 66 an error
file: /home/s/OpenFoam/incompressible/simpleFoam/enterprise/constant/polyMesh/boundary at line 66.
From function Istream::readEndList(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 151.
FOAM exiting
boundary card ;;;;
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
8231
maxY
type patch;
nFaces 100;
startFace 1495590;
minX
type symmetryPlane;
nFaces 274;
startFace 1495690;
maxX
type symmetryPlane;
nFaces 274;
startFace 1495964;
minY
type patch;
nFaces 100;
startFace 1496238;
minZ
type symmetryPlane;
nFaces 250;
startFace 1496338;
maxZ
type symmetryPlane;
nFaces 250;
startFace 1496588;
stlSurface_patch8224
type wall;
nFaces 138925;
startFace 1496838;
basilwatson is offline   Reply With Quote
Old   November 27, 2010, 07:31
Retired Super Moderator
Bruno Santos
Greetings Stephen,
OK, two things:
  1. you should have compressed and attached the file, instead of copy-pasting it This way we cannot verify if there is an illegal invisible character
  2. Your file is stating that there are 8231 boundaries, when only 7 are listed! That should be why the parser expected more things to come, instead of the end of the file!
By the way, 8231 boundaries? That must have been one hell of an import!
Best regards,
Bruno
Old   November 27, 2010, 10:06
Stephen
Hi there
most likely the numbering , I was ok with simple shapes all going well , so then I decided to see if I could get the Space Ship Enterprise to model
Well you never know!
I did get it to run through once but with a very course mesh , and I had missed a boundary face , , but for some reason I couldnt get it to run again , with the resulting error
yes it was big but not too bad !
I try and attach a zip file I would like to see what happens !
Thanks for the Help
Stephen
Old   November 28, 2010, 08:36
Bruno Santos
Hi Stephen,
Uhm... does this mean that you have been able you use it now, or does the same error still occur?
By the way, if the mesh is too coarse - as we can see in the boundary file you attached - there are a lot of patches with zero faces... And setting boundary conditions for these faces might render the simulation impossible to execute. But I don't remember never trying this, so I don't know exactly what will the outcome be.
Ah, another note: you can try AdMesh to plug any holes there might be in the STL file.
Best regards,
Bruno
Old   November 30, 2010, 09:14
Stephen
tried a more simple mesh and it ran ok
I will come back to the enterprise when I have more time
I have attached a screen shot of the new mesh , any tips about mesh size or how to run it ?( ps its a little nws maybe? its the only mesh I had for another Job )
I am searching now , so any help is valuable
Thank you for your help so fay , most appreciated !
Stephen
Old   August 21, 2013, 09:07
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by wyldckat View Post
Hi Stephen,
Best regards,
Bruno
Dear bruno, i have downloaded the admesh-0.95, and i have executed the instructions, as i read in the INSTALL file, my question is, how should i run it ?
i can't use it because i can't run it, would you please guide me.
Thank you very much
This is what i do, for making admesh .
saeide@linux:~/good/zipfiles> tar -zxvf admesh-0.95.tar.gz
admesh-0.95/
admesh-0.95/ADMESH.DOC
admesh-0.95/COPYING
admesh-0.95/ChangeLog
admesh-0.95/INSTALL
admesh-0.95/Makefile.in
admesh-0.95/README
admesh-0.95/admesh.c
admesh-0.95/block.stl
admesh-0.95/configure
admesh-0.95/configure.in
admesh-0.95/connect.c
admesh-0.95/getopt.c
admesh-0.95/getopt.h
admesh-0.95/getopt1.c
admesh-0.95/normals.c
admesh-0.95/shared.c
admesh-0.95/stl.h
admesh-0.95/stl_io.c
admesh-0.95/stlinit.c
admesh-0.95/util.c
saeide@linux:~/good/zipfiles> cd admesh-0.95
saeide@linux:~/good/zipfiles/admesh-0.95> ./configure
loading site script /usr/share/site/x86_64-unknown-linux-gnu
creating cache ./config.cache
checking for gcc... gcc
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for -lm... yes
checking for getopt_long... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
saeide@linux:~/good/zipfiles/admesh-0.95> make
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o admesh.o admesh.c
admesh.c:31:1: warning: return type of ‘main’ is not ‘int’ [-Wmain]
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o connect.o connect.c
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o stl_io.o stl_io.c
stl_io.c: In function ‘stl_write_ascii’:
stl_io.c:135:2: warning: implicit declaration of function ‘strlen’ [-Wimplicit-function-declaration]
stl_io.c:135:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
stl_io.c: In function ‘stl_print_neighbors’:
stl_io.c:181:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
stl_io.c: In function ‘stl_write_binary’:
stl_io.c:254:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
stl_io.c:263:11: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
stl_io.c: In function ‘stl_write_quad_object’:
stl_io.c:354:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
stl_io.c: In function ‘stl_write_dxf’:
stl_io.c:430:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o stlinit.o stlinit.c
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o util.o util.c
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o normals.o normals.c
normals.c: In function ‘stl_fix_normal_directions’:
normals.c:98:7: warning: variable ‘checked_before’ set but not used [-Wunused-but-set-variable]
gcc -I. -g -O -O2 -Wall -Wno-implicit   -c -o shared.o shared.c
shared.c: In function ‘stl_write_off’:
shared.c:159:2: warning: implicit declaration of function ‘strlen’ [-Wimplicit-function-declaration]
shared.c:159:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
shared.c: In function ‘stl_write_vrml’:
shared.c:197:14: warning: incompatible implicit declaration of built-in function ‘strlen’ [enabled by default]
gcc  -o admesh admesh.o connect.o stl_io.o stlinit.o util.o normals.o shared.o  -lm
File Type: txt INSTALL-admesh.txt (2 Bytes, 4 views)
s.m is offline   Reply With Quote
Old   August 21, 2013, 10:21
Bruno Santos
Hi Saeideh,
Either check the links given at this page: http://openfoamwiki.net/index.php/Sn...xing_STL_files
Or try running:
admesh -help
Best regards,
Bruno
Old   August 21, 2013, 13:15
s.m
saeideh mohamadi
Hi Saeideh,
Or try running:
admesh -help
Best regards,
Bruno
Hi Bruno, i do what was write un that site, but it doesn't run!
This is what i do:
saeide@linux:~/good/zipfiles/admesh-0.95> sudo apt-get install admesh
root's password:
sudo: apt-get: command not found
saeide@linux:~/good/zipfiles> admesh -help
If 'admesh' is not a typo you can use command-not-found to lookup the package that contains it, like this:
    cnf admesh
Old   August 21, 2013, 13:45
Bruno Santos
Hi Saeideh,
For posting code, please follow the instructions given on the second link on my signature.
As for using AdMesh, since you compiled it from source, you should use the version you have, namely by running from within the folder "~/good/zipfiles/admesh-0.95" like this:
./admesh -help
If you want to make it possible to simply run:
admesh
edit your "~/.bashrc" file and add this line to it:
export PATH=$PATH:/home/good/zipfiles/admesh-0.95
Then start a new terminal window or tab.
Best regards,
Bruno
s.m likes this.
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
