Questions about LTSInterFoam
Hi all,
i am playing a bit with LTSInterFoam. The idea is to simulate the steady state movement of a meniscus in different capillary tubes and compare the solution with the unsteady one. As a starting point i had a look at wigleyHull tutorial in which everything seems to work fine. Then i took the capillary rise tutorial of interFoam and i tried to get a steady state solution with LTSinterfoam, using the same BC. I played with many different combination of schemes and solvers with no success: or the solution diverges (alpha explodes, continuity errors explode) or the solution is physically not correct. When the meniscus reaches the equilibrium configuration i think a steady state solution should exist, so where i am doing wrong? Are there any limitations using this solver? Is the presence of capillary pressure that might generate problems (in wigleyHull tut, sigma is set to zero)? thanks andrea |
Problem solved?
Dear Andrea,
have you ever managed to solve this issue? I also try to get a steady state meniscus but the simulation explodes always. Really appreciate your feedback. All the best, Axel |
