-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   mapField & core dumped (http://www.cfd-online.com/Forums/openfoam/122623-mapfield-core-dumped.html)
sasanghomi August 23, 2013 07:15
Hi Foamers ,
I want to use mapField utility for two consistent geometry. but I have a problem!!!:(
Any body know how can I overcome this problem?
sasan@sasan-Inspiron-N5110:~/Desktop/mapField/cold3$ mapFields ../cold2 -consistent
| \\      /  F ield        | OpenFOAM Extend Project: Open source CFD        |
|  \\    /  O peration    | Version:  1.6-ext                              |
|  \\  /    A nd          | Web:      www.extend-project.de                |
|    \\/    M anipulation  |                                                |
Build  : 1.6-ext-959ec266ba5c
Exec  : mapFields ../cold2 -consistent
Date  : Aug 23 2013
Time  : 15:35:37
Host  : sasan-Inspiron-N5110
PID    : 4345
Case  : /home/sasan/Desktop/mapField/cold3
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Source: ".." "cold2"
Target: "/home/sasan/Desktop/mapField" "cold3"
Create databases as time
Source time: 0
Target time: 0
Create meshes
Source mesh size: 246165    Target mesh size: 704880
Found 423274 cells outside of the addressing
Cell addressing size = 704880
Consistently creating and mapping fields for time 0
fileName::stripInvalid() called for invalid fileName pointMotionUvelocityLaplacian~
    For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
I appreciate any help from you
Thanks and best regards
Sasan.
sasanghomi August 23, 2013 07:34
I found the origin of this problem..there was an invalid file in the 0 directory. But I have a new question!! Why after mapField there is no a new file ( for new time step ) in the case directory ? ..It doesn't create a new file for new running..Why? anybody can help me?
Date  : Aug 23 2013
Time  : 15:57:20
PID    : 4639
nProcs : 1
Source time: 0
Target time: 0
Create meshes
    interpolating alphat
    interpolating p
    interpolating T
    interpolating k
    interpolating epsilon
    interpolating mut
    interpolating U
End
Bernhard August 23, 2013 09:59
Because it overwrites your present ./0 folder.
sasanghomi August 23, 2013 10:08
thanks for your reply.
I should remove 0 file before mapField?
Bernhard August 23, 2013 10:10
No, it will just overwrite the old files.
