-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Turbulent Kinetic Energy Budget (http://www.cfd-online.com/Forums/openfoam/122699-turbulent-kinetic-energy-budget.html)
skyinventorbt August 26, 2013 06:28
1 Attachment(s)
This utility creates scalar fields of Advection & Production of Turbulent Kinetic Energy by reading U, R & k files.
Usage Instructions
  1. Extract the zip and paste tkeFoam folder to /opt/OpenFOAM-2.1.1/applications/utilities/
  2. [In Terminal] cd /opt/OpenFOAM-2.1.1/applications/utilities/tkeFoam/ and then wmake
  3. After compilation use "tkeFoam -latestTime" or "tkeFoam" in your case.
:)Hope it will be useful:)
KANNAN B T
mmmn036 April 29, 2014 20:26
This is only good for RASModel. How to implement this one in LESModel?
Thanks
MMMN
skyinventorbt April 30, 2014 23:43
Thanks
MMMN
Obviously it cannot be used for LES.
From the data set you generate using LES - will have all the fluctuating and mean quantities - so you could write your own utility using the syntax provided in the Programmers Guide.
KANNAN B T
