Problem going from incompressible to compressible
Hi everyone,
I am relatively new to OpenFOAM and in the past only ran simulations with the incompressible assumption. Now my research requires me to run without this assumption ie. compressible flow. I ran some simulations using simpleFoam and got good results. I am now trying to run the same simulations with rhoSimpleFoam. The simulation has zero pressure gradient and zero temperature gradient. The first simulation is just flow over a flat plate at M=0.2 so the compressibility should only have a very small affect. However, when I run the simulations with rhoSimpleFoam I get an error that says "Maximum number of iterations has been exceeded." After looking through different forums I saw that this error is probably due to initial/boundary conditions. Since the simulation ran and produced good results running in incompressible mode, the only files that are different are for temperature, alphaT, and the thermophysicalProperties. I was wondering if anyone could look these over and make sure that I have not made some silly error. Thanks, -Ben My boundary conditions for temperature and alphaT are shown below, as well as the thermophysicalProperties file Code:
thermoType Code:
internalField uniform 300; Code:
internalField uniform 0; |
I think your problem might be related to this: http://www.cfd-online.com/Forums/ope...tml#post425211
What are your U and p/p_rgh boundary conditions? You could also try the (transient) pimple solver. |
