automatic shut down the PC after ending of run |
December 25, 2013, 18:03 |
#21 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Using the sync command could have helped as well, since it would emphasize the need to do some more writing of the files that were still ongoing. Either way, waiting more than 4 minutes might have helped, but it's not guaranteed either. As for possibly recovering the files, it would have been necessary an auxiliary hard drive, in order to attempt searching for the missing files and copying them from one hard-drive to the other. The other possibility would have been to undelete them directly on the Linux partition, which could have worked, if nothing else was written on top of it. Although in either situation, an auxiliary hard-drive would have been necessary. Quote:
Usually in these situations, usually the first rule of file recovery is: don't touch anything (or at least don't write any new files), as soon as you detected that something is missing. |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
What's the best order to run this simulation in? | siw | CFX | 1 | November 4, 2009 19:42 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 08:33 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
