New boundary condition in solver
Like Tree1Likes
  • 1 Post By jherb
Old   September 2, 2013, 12:15
Default New boundary condition in solver
Richard
Ricardo is on a distinguished road
Hello, I have new boundary condition "convectiveValue" based on fixedValue condition.
I would like use this code in my solver
 if(T.boundaryField()[patchID1].type() == convectiveValueFvPatchScalarField::typeName)
    {convectiveValueFvPatchScalarField& tValue = refCast<convectiveValueFvPatchScalarField>(T.boundaryField()[patchID1]);
I get error message
 mylaplacianFoam.C:(.text.startup+0x1f95): undefined reference to `Foam::convectiveValueFvPatchField<double>::typeName'
collect2: ld returned 1 exit status
I have #include "convectiveValueFvPatchFields.H" in solver file and link to header in Make/options
any Idea what is wrong?
Thanks
Richard
Ricardo is offline   Reply With Quote
Old   September 3, 2013, 00:17
Nima Samkhaniani
nimasam is on a distinguished road
besides library path you should name library binary file which you want to add in the section
EXE_LIBS
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 3, 2013, 03:08
Richard
I added it, but nothing changed..
EXE_INC = -I$(LIB_SRC)/finiteVolume/lnInclude\
        -I$(FOAM_RUN)/Newton/
EXE_LIBS = -lfiniteVolume \
            -L$(FOAM_USER_LIBBIN)/libconvectiveValue.so
Old   September 3, 2013, 09:04
Joachim Herb
jherb is on a distinguished road
Try:
            -L$(FOAM_USER_LIBBIN) \
            -lconvectiveValue
(under the assumption that your library is called libconvectiveValue.so and resides in $FOAM_USER_LIBBIN)
nimasam likes this.
jherb is offline   Reply With Quote
Old   September 3, 2013, 13:20
Richard
It works, thank You very much!
Old   September 4, 2013, 06:27
Richard
Hello, I have a little question about using interpolationTable. I would like using data measured data ("$FOAM_CASE/constant/sample.dat") for calculating of BC. I tried various combination of constructors, but without succes.
interpolationTable<List<Tuple2<scalar,scalar> > >
Would you be so kind and give me a sample of code for interpolating scalar value from file?
Thanks
Richard
Solved: bad generic types...
access boundary condition from solver pascool OpenFOAM Programming & Development 2 April 30, 2015 08:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 07:09
