mechy |
September 20, 2013 17:40 |
how I can increase the accuracy of flow pressure ?
i all
I have simulated flow around a cylinder by OF and FLUENT
In both software, I use a high quality and fine structure mesh which lead to y+<5 over walls and use Kw-sst model
also the setting for OF and FLUENT is as follow
FLUENT BCs:
inlet ========> velocity inlet U=7m/sec k=.2 omega=170
outlet=======> pressure outlet
FLUENT settigs
solver =============> PISO
residual=1e-5
In OF I have used pimpleFoam and setting are as follow
any help will be appreciated
object k;
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 0.2;
boundaryField
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform .2;
circle
type kLowReWallFunction;
value uniform 1e-6;
frontAndBackPlanes
type empty;
object omega;
dimensions [ 0 0 -1 0 0 0 0 ];
internalField uniform 170;
boundaryField
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 170;
circle
type omegaWallFunction;
value uniform 1e-6;
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
circle
type fixedValue;
value uniform ( 0 0 0 );
wall
type fixedValue;
inlet
type fixedValue;
value uniform ( 7. 0 0 );
outlet
type zeroGradient;
object nut;
dimensions [ 0 2 -1 0 0 0 0 ];
internalField uniform 0;
boundaryField
wallup
type nutUSpaldingWallFunction;
value uniform 0;
wallp
value uniform 0;
outlet
type calculated;
value uniform 0;
inlet
type calculated;
value uniform 0;
circle
value uniform 0;
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear ;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;//
div(phi,omega) Gauss limitedLinear 1;//
div((nuEff*dev(T(grad(U))))) Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
// pcorr ;
p;
solvers
p
solver GAMG;
tolerance 1e-5;
relTol 0;
smoother GaussSeidel;
nPreSweeps 1;
nPostSweeps 2;
cacheAgglomeration true;
directSolveCoarsest true;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 100;
mergeLevels 1;
minIter 1;
pFinal
solver GAMG;
tolerance 1e-9;
relTol 0;
nPreSweeps 1;
nPostSweeps 2;
mergeLevels 1;
minIter 1;
"(U|k|omega)"
solver smoothSolver;
tolerance 1e-5;
relTol 0;
nSweeps 1;
minIter 1;
"(UFinal|kFinal|omegaFinal)"
tolerance 1e-6;
relTol 0.0;
nSweeps 1;
minIter 1;
PIMPLE
nOuterCorrectors 4;
nCorrectors 2;
nNonOrthogonalCorrectors 3;
pRefCell 0;
pRefValue 0;
correctPhi no;
// momentumPredictor yes;
