samiam1000 |
September 23, 2013 08:46 |
Solid properties: thermophysicalPropertiesDict
Dear All,
I am gonna run a chtMultiRegionSimpleFoam case and I have a domain filled with air, in which there are 2 solids: a block of ice and a PCM that stays all around the ice.
I would like to understand if it is possible to model the phase changing in OpenFoam. How can I introduce the latent heat? And the temperature of this phase changing? Could you provide the right paramters (both for ice and for PCM) that should be inserted in this dictionary?
Thanks a lot,
Samuele
Dictionary:
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object thermophysicalProperties;
thermoType
type heSolidThermo;
mixture pureMixture;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
mixture
specie
nMoles 1;
molWeight 12;
transport
kappa 80;
thermodynamics
Hf 0;
Cp 450;
equationOfState
rho 8000;
