Home > Forums > OpenFOAM
swak4Foam & Radial velocity
Like Tree2Likes
  • 2 Post By gschaider
Old   September 27, 2013, 11:09
Default swak4Foam & Radial velocity
Sasan Ghomi
sasanghomi is on a distinguished road
Hi foamers
I have two questions about swak4Foam :
1) I want to calculate radial velocity in an engine . Can I do this action by using swak4Foam? How? which type ? Can you write an example here?
2) How can I calculate an expression according to variables ? for example I want to use probe and I want to have sqrt(2*k/3) in a specific point versus time { k is turbulent energy }.How can I do that?
I appreciate any help,
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   September 27, 2013, 15:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by sasanghomi View Post
Hi foamers
I've got to hand you back this question: can you be more specific? Do you want a new field, an average or what? You want it during the run or afterwards? And what is your definition of "radial velocity"?
Anyway: if you can write that definition as an expression on a piece of paper then you can calculate it in swak (probably in terms of velocity, position and the axis). Only thing you need to know is that & is the inner product of two vectors and ^ is the cross product (but you were probably aware of that if you looked at the Wiki-page and the incomplete reference guide http://openfoamwiki.net/images/d/db/...mReference.pdf)
That'd be a swakExpression-function object with valueType "set". There are examples for that in the Examples-folder of the distro and something like that is for instance explained in the presentation from the 6th workshop (linked from the Wiki-page)
Please have a look at the mentioned presentation and the reference guide before asking further. I only have a limited amount of time for supporting these things and every time I answer questions that are already documented I have less time to complete the actual documentation.
Mojtaba.a and sasanghomi like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 28, 2013, 05:44
Sasan Ghomi
Dear Bernhard ,
Thank you very much for your reply and I am sorry for asking simple question.
I appreciate your help and your attention.
I have another question . Can you help me?
I want to calculate engine swirl :
w=\frac{\int (\vec{r}\times \vec{v})dV}{\int \vec{r}^{2}dV}
That : {v= velocity & V=volume & r = position & Rs=swirl ratio &N=rpm}
R_{s}=\frac{w_{z}}{2\pi N}
I want to calculate Rs. Can I calculate Rs by using swak4Foam? I think swak doesn't have integration.Also I don't know how can I use r vector in swak !!! Can you guide me?
Best regards
Sasan.
Thread Tools
Trackbacks are On
swak4Foam: problem with a parabolic velocity profile Claudio87 OpenFOAM Pre-Processing 5 May 29, 2014 09:30
tangential, axial and radial velocity in swirling Al-Hashimi FLUENT 1 June 23, 2013 10:30
Axial, Radial, Tangental velocity in FLUENT post Barri FLUENT 2 March 6, 2008 21:29
Radial Position and Axial Velocity Graph Sal FLUENT 2 August 1, 2007 09:29
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
