compressibility of water???
hello!
Could you tell me if the OpenFOAM have a or some solver which can take into account the compressibility of water? And what is the solver name? thank you! |
as far as I know - not really. But I do not know which thermodynamics are available with rho***Foam. I have no FOAM here to check it out, but you can get the possible models if you use the banana trick. Regards Tobi |
the rho*Foam solver can not be used for that. But maybe the following solver is okay for you: http://openfoamwiki.net/index.php/SonicLiquidFoam Regards Tobi |
thank you ! |
