Wavemaker using a piston type with dynamic mesh
Old   October 28, 2013, 22:58
Default Wavemaker using a piston type with dynamic mesh
alejandro cáceres
alejoopefoa is on a distinguished road
Good day,
I try to simulate a waveflume using a dynamic mesh.
In this case i try with dynamicinkjetFvmesh, but when i run the model the mesh is good (moving) but the water does not simulate the paddle behavior(does not move).
My library is interDyFoam
Thanks for your help.
alejoopefoa is offline   Reply With Quote
Old   November 4, 2013, 04:21
Artur's Avatar
Artur
Artur will become famous soon enough
There can be numerous sources of the behaviour you're describing (my first blind guess would be alpha boundary conditions). It would be helpful to know a bit more about your case (pictures showing how the mesh looks like and how the water actually behaves, boundary condition files, etc.).
All the best,
A
Artur is offline   Reply With Quote
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 10:44
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
