Error when post-processing turboPassageRotating2D
Old   November 1, 2013, 03:09
Angry Error when post-processing turboPassageRotating2D
Minh-VietNam
mingbn is on a distinguished road
Hi. Everybody.
I'm a new openFoam user. so i can not launch this case. I don't know how to fix the error. Can you help please.
This is case (case of an master thesis which downloaded from web http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/)
thanks a lot!
This is error:
--> FOAM FATAL IO ERROR:
Cannot find 'value' entry on patch rotor_cyclic_upper of field p in file "/home/minh/Desktop/turboPassageRotating2D/0/p"
which is required to set the values of the generic patch field.
(Actual type cyclicGgi)
Please add the 'value' entry to the write function of the user-defined boundary-condition
file: /home/minh/Desktop/turboPassageRotating2D/0/p.boundaryField.rotor_cyclic_upper from line 43 to line 43.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file genericFvPatchField/genericFvPatchField.C at line 71.
FOAM exiting
Please show to me, thankS!
mingbn is offline   Reply With Quote
Old   November 4, 2013, 04:18
Artur's Avatar
Artur
Artur will become famous soon enough
Can you post the pressure boundary condition file of your case (since that's where the problem is occurring)?
As a side note, I think the title of your post is a bit misleading.
All the best,
A
Artur is offline   Reply With Quote
Old   November 4, 2013, 05:13
Angry turboPassageRotating2d
Minh-VietNam
All the best,
A
ThankS.
This is my pressure boundary condition.
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
fixedWalls
type zeroGradient;
movingwalls
type zeroGradient;
rotor_cyclic_upper
type cyclicGgi;
rotor_cyclic_lower
type cyclicGgi
stator_cyclics_half0
type cyclic;
interface1
type overlapGgi;
interface2
type overlapGgi;
stator_cyclics_half1
type cyclic;
Old   November 4, 2013, 06:08
Artur's Avatar
Artur
Alright, I think you're using an older version of FOAM since you have "GGI" instead of "AMI", am I right? If yes then I cannot help you since I've only used 2.x and above for sliding meshes. Nonetheless, this is how I define the AMI pressure BC in 2.1.x and 2.2.x and it works:
AMI1
        type            cyclicAMI;
        value           uniform 0;
Maybe check the tutorials/incompressible/pimpleDyMFoam tutorials for the version you are using. There should be either a mixerVessl or propeller which use AMI or GGI.
Good luck,
A
Old   November 4, 2013, 22:48
Smile
Minh-VietNam
AMI1
        type            cyclicAMI;
        value           uniform 0;
Good luck,
A
Thank you very much for your help.
I am using OpenFoam 2.2.1. I wil try following your advive.
post processing for CEL expressions Niru CFX 0 May 10, 2013 13:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 06:21
CFD post processing techniques & streamlining klk Main CFD Forum 0 October 19, 2010 07:37
fluent for post processing James FLUENT 0 April 21, 2006 04:43
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
