Home > Forums > OpenFOAM
probe one quantity using libsampling.so
Old   November 3, 2013, 20:58
Question probe one quantity using libsampling.so
openfoammaofnepo is on a distinguished road
Dear All,
I am doing an unsteady simulation and for each time instant, I calculate the maximum temperature for the whole domain:
scalar Tmax=max(T).value;
Then I add Tmax in the list of probe:
probes
type probes;
functionObjectLibs ("libsampling.so");
enabled true;
outputControl timeStep;
outputInterval 1;
fields
rho
Tmax
probeLocations
#include "probeLocations"
The density can be correctly extracted for each time step however Tmax cannot. Does anybody how to make Tmax also output using probe? Thank you very much.
openfoammaofnepo is offline   Reply With Quote
Old   November 4, 2013, 03:07
Bernhard
Bernhard is on a distinguished road
Why would you probe a global variable like Tmax locally, that doesn't make sense? Also, where did you put this line where you define? I think you have many options here with a function object: 1. coded function object, which is default OpenFOAM syntax in newer version or 2. swakExpression, which makes it really easy to track a maximum. 3. I can imagine there is a default function object which you could use instead of probes.
Bernhard is offline   Reply With Quote
Old   November 4, 2013, 04:55
Thank you very much. Yes I know but I would like to output this global quantity into a file not just print on the monitor. I do not really understand the function object you mentioned. Could you please nicely say it more specifically?
Thank you.
Thread Tools
Trackbacks are On
Line Probe Smoothing badger1 STAR-CCM+ 1 May 21, 2013 22:36
Heat transfer/Temperature along a tube and probe. moienfar-CFD FLUENT 4 March 4, 2013 12:29
Calculate a quantity based on another quantity solved by Openfoam. hz283 OpenFOAM 10 December 27, 2012 02:47
new atmospheric probe design manobianco Main CFD Forum 0 May 12, 2012 15:04
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 5 November 8, 2009 04:47
