Wavemaker using a piston type with dynamic mesh |
October 28, 2013, 22:58 |
alejandro cáceres
Rep Power: 12 |
Good day,
I try to simulate a waveflume using a dynamic mesh. In this case i try with dynamicinkjetFvmesh, but when i run the model the mesh is good (moving) but the water does not simulate the paddle behavior(does not move). My library is interDyFoam Thanks for your help. |
November 4, 2013, 04:21 |
Artur
Rep Power: 19 |
There can be numerous sources of the behaviour you're describing (my first blind guess would be alpha boundary conditions). It would be helpful to know a bit more about your case (pictures showing how the mesh looks like and how the water actually behaves, boundary condition files, etc.). All the best, A |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
