-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Cyclic boundary giving wrong gradient (http://www.cfd-online.com/Forums/openfoam/126374-cyclic-boundary-giving-wrong-gradient.html)
rakue November 15, 2013 09:41
I'm trying to simulate a simple test case. A fully developed laminar flow through a channel with simpleFoam using cyclic BC on the inlet and outlet (simple 2D channel, length 0.5 m height 0.05 m, viscosity 100 Pas, rho 1000 kg/m3).
I set up the average cyclic velocity ubar (0.05 0 0) into the fvOptions dict and setup 'type cyclic' for the inlet and outlet boundaries.
After solving the case i get the expected parabolic velocity profile.
Looking into the log for the pressure gradient, I got a number with the correct magnitude (expected -24.0), but the wrong sign (.. "Pressure gradient source: uncorrected Ubar = 0.05, pressure gradient = 23.666" ...)
As the channel flow is driven by the pressure gradient, it should be negative ???!
Can anybody give me a hint, what's going wrong?
Thanks
