B in the tutorials pisoFoam (LES) cases
Like Tree2Likes
  • 1 Post By wyldckat
  • 1 Post By luuhoangthien
Old   March 7, 2013, 09:04
Default B in the tutorials pisoFoam (LES) cases
Jian Zhong
zxj160 is on a distinguished road
Dear Foamers,
I am practicing pisoFom solver for the pitzDaily LES case. I notice 'B' is in the time 0 file. But in later time output files, there is no 'B'. I reviewed the 'creatFields.H' file in the pisoFoam solver, but I did not find a declaration for 'B'.
Does anyone know where can I find the declaration of 'B'? And what does 'B' mean?
My best regards,
Jian
zxj160 is offline   Reply With Quote
Old   March 7, 2013, 10:50
Bernhard
Bernhard is on a distinguished road
Which LES model are you using?
The tutorial case you refer to uses the oneEqEddy model. If you open oneEqEddy.H (see src folder), you'll see the definition of B (although not used in the code as far as I see).
Bernhard is offline   Reply With Quote
Old   March 7, 2013, 12:39
Jian Zhong
Yes, I used the oneEqEddy model. In the GenSGSStress.C file in the file of '/apps/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LES/GenSGSStress', I find
B_
IOobject
"B",
runTime_.timeName(),
mesh_,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh_
B should be 'AUTO_WRITE' during the running time. But when I run the tutorial case, B is only in the time 0 file. Later, it is gone.
Old   March 7, 2013, 12:41
Akbar Mohammadi Ahmar
akbarMohammadiAhmar is on a distinguished road
Hi Jian Zhong
B in LES models is Stress tensor similar R in RANS models in OpenFoam.
Have you B in 0 Folder?
I think B is in creditfield and you must see that in creditfield B is defined or no?
akbarMohammadiAhmar is offline   Reply With Quote
Old   March 7, 2013, 16:55
Jian Zhong
Originally Posted by akbarMohammadiAhmar View Post
Hi Jian Zhong
I test that if I delete B in time 0, pisoFoam (LES, oneEqEddy model) can still run well for the tutorial pitzDaily case.
Old   March 7, 2013, 17:45
Retired Super Moderator
Bruno Santos
Greetings to all!
Those "B" files were removed in OpenFOAM 2.1.x in August 2012: https://github.com/OpenFOAM/OpenFOAM...a52c14701a61d2
This was done around 2 months after 2.1.1 was released.
Best regards,
Bruno
Tobi likes this.
Old   November 28, 2013, 20:51
ThienMa
luuhoangthien is on a distinguished road
Dear zxj160,
You can modified solver to get R in RANS or B in LES.
view source code Utility R in OpenFOAM to get idea and get B in LES
Thien
wyldckat likes this.
luuhoangthien is offline   Reply With Quote
creatfields, les model, pisofoam
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx Jaro OpenFOAM Running, Solving & CFD 8 March 16, 2016 07:27
Beginning to work in LES - Suggestions needed atmcfd Main CFD Forum 5 July 20, 2012 22:16
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
LES - standard test cases? Mario Main CFD Forum 2 October 14, 2004 02:48
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
