Question about gradient scheme
Old   January 16, 2014, 22:07
Default Question about gradient scheme
Tayo
tayo is on a distinguished road
I'm puzzled about the way openfoam computes the gradient scheme. I have a temperature field, T that varies between 358 - 400K and I simply take the gradient using fvc::grad(T), with Gauss linear scheme. With a mesh size is approx. 0.3 mm, some of the results for the gradient are printed below:
const volScalarField& T = alpha1_.db().lookupObject<volScalarField>("T");
volVectorField gradT = fvc::grad(T);
Info << "gradT =" << gradT << endl;
(-164633 -164633 0)
(0 -164633 0)
(0 -164633 -2.98156e-10)
(0 0 2.98156e-10)
(0 0 1.49078e-10)
(164633 -164633 0)
(0 0 0)
(0 0 0)
(164633 0 0)
(0 0 0)
Some of my basic questions are:
1.) Why does it print out negative numbers?
2.) How does it get gradient values of (0 0 0) when the T values vary between 358 - 400K.
3.) Why is the z- gradient values so low (2.98156e-10) considering the small mesh size?
Kindly help explain what's happening here. Thanks
tayo is offline   Reply With Quote
Old   January 17, 2014, 02:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Quite usual questions:
1. What type of BCs do you use?
2. Can you post checkMesh output?
3. Can you post your fvSchemes?
4. Can you post your case files?
alexeym is offline   Reply With Quote
Old   January 17, 2014, 03:58
akidess's Avatar
Anton Kidess
Post plots of T and gradT from paraview as well.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 18, 2014, 11:57
Tayo
Thanks for the response. Below is my boundary condition
Temp.: fixedGradient on wall, fixedValue inlet, zeroGradient outlet
Pressure: zeroGradient inlet and wall, fixedValue outlet
Velocity: no slip wall, fixedValue inlet, zeroGradient outlet
Here is my fvScheme:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
gradSchemes
divSchemes
    div(rho*phi,U)  Gauss limitedLinearV 1;
    div(phi,T)  Gauss upwind;
    div(phi,p_rgh)  Gauss upwind;
    div(phi,alpha)  Gauss vanLeer01;
    div(phirb,alpha) Gauss interfaceCompression;
The checkMesh also seems ok:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            267729
    internal faces:   254991
    cells:            87120
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     87120
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    inlet               2640     2754     ok (non-closed singly connected)
    outlet              2640     2754     ok (non-closed singly connected)
    heatWall            7458     7684     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 0 0) (0.02 0.01 0.01)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (3.88444e-16 1.23164e-16 -3.56799e-15) OK.
    Max cell openness = 8.82326e-17 OK.
    Max aspect ratio = 1.33333 OK.
    Minumum face area = 7.5e-08. Maximum face area = 1.0101e-07.  Face area magnitudes OK.
    Min volume = 2.27273e-11. Max volume = 2.52525e-11.  Total volume = 2e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.000109995 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
Time = 0.0005
Mesh stats
    faces:            272670
    internal faces:   259779
    cells:            88618
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       1
    hexahedra:     88339
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     279
    Point usage OK.
    Face vertices OK.
    heatWall            7611     7859     ok (non-closed singly connected)
    Boundary openness (-4.07224e-16 3.9387e-17 -3.50976e-15) OK.
    Max cell openness = 1.76465e-16 OK.
    Max aspect ratio = 1.33336 OK.
    Minumum face area = 4.6875e-09. Maximum face area = 1.01015e-07.  Face area magnitudes OK.
    Min volume = 3.55078e-13. Max volume = 2.52538e-11.  Total volume = 2e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 29.6211 average: 1.53168
    Face pyramids OK.
    Max skewness = 0.334633 OK.
Mesh OK.
The issue seems to be with the gradScheme. It gives fairly the same result when for fvc::grad(T) and fvc::grad(T-TSat) where TSat is a dimensionedScalar at 371K while T is a volScalarField defined in previous post.
volScalarField gradT = mag(fvc::grad(T));
volScalarField gradTt = mag(fvc::grad(T-TSat));
Info << min(gradT) << max(gradT) << min(gradTt) << max(gradTt) << endl;
Checking the min. & max. values for mag(grad(T)) and mag(grad(T-TSat) shows that they are exactly the same. This is clearly wrong but I don't understand why. However, when I compute these values by postprocessing with funkySetField, I get more reasonable result as shown in the plots. So my question is this: why are these two grad(T-TSat) results significantly different? How do I best define grad(T-TSat) to give the expected result? Thanks
Old   January 20, 2014, 09:12
Alexey Matveichev
Concerning grad(T) and grad(T - Tsat), as Tsat is constant, grad(Tsat) = 0 and grad(T) = grad(T - Tsat).
From you graphs I can see the areas of constant temperature, so in these areas grad(T) will be 0.
And finally negative numbers - we need to continue guessing what are the real initial and boundary conditions.
question on simulating rotating channel with a pressure gradient huangxianbei CFX 10 January 14, 2014 23:00
Crank Nicolson scheme msrinath80 OpenFOAM Running, Solving & CFD 6 November 14, 2010 13:59
Question about gamma intgerpolation scheme titio OpenFOAM Running, Solving & CFD 0 July 26, 2010 10:22
Scheme file for sinusoidal channel flow elobb FLUENT 0 November 24, 2009 10:27
Question about meshing / solution scheme of CFX Coriolius CFX 8 August 1, 2004 18:39
