January 26, 2014, 09:07 |
Problems simulating deformation
Rep Power: 12 |
I am currently trying to simulate the deformation in a component with a force applied to its top surface whilst held at the bottom, for this I used the solidDisplacementFoam. When I simulate this it looks like only the top section of the geometry is being simulated: https://imageshack.com/i/gok0r2p My blockMeshDict and my boundary condition (D) is shown below (only things changed from original playeHole tutorial). Code:
/*--------------------------------*- C++ -*----------------------------------*/ // File was generated by SwiftBlock, a Blender 3D addon. FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (16.10484504699707 12.70164966583252 0.0) (14.10484504699707 10.70164966583252 0.0) (9.85484504699707 11.70164966583252 0.0) (10.85484504699707 10.70164966583252 0.0) (16.10484504699707 29.681650161743164 0.0) (13.154845237731934 23.201648712158203 0.0) (16.10484504699707 18.401649475097656 0.0) (13.154845237731934 18.401649475097656 0.0) (16.10484504699707 23.201648712158203 0.0) (14.35484504699707 29.681650161743164 0.0) (14.35484504699707 34.061649322509766 0.0) (9.85484504699707 18.401649475097656 0.0) (9.85484504699707 23.201648712158203 0.0) (9.85484504699707 29.681650161743164 0.0) (9.85484504699707 34.061649322509766 0.0) (16.10484504699707 12.70164966583252 1.0) (14.10484504699707 10.70164966583252 1.0) (9.85484504699707 11.70164966583252 1.0) (10.85484504699707 10.70164966583252 1.0) (16.10484504699707 29.681650161743164 1.0) (13.154845237731934 23.201648712158203 1.0) (16.10484504699707 18.401649475097656 1.0) (13.154845237731934 18.401649475097656 1.0) (16.10484504699707 23.201648712158203 1.0) (14.35484504699707 29.681650161743164 1.0) (14.35484504699707 34.061649322509766 1.0) (9.85484504699707 18.401649475097656 1.0) (9.85484504699707 23.201648712158203 1.0) (9.85484504699707 29.681650161743164 1.0) (9.85484504699707 34.061649322509766 1.0) ); blocks ( hex (15 16 18 17 0 1 3 2) (2 5 1) edgeGrading ( 1 1 1 1 1 1 1 1 1 1 1.0 1.0) hex (0 6 11 2 15 21 26 17) (6 5 1) edgeGrading ( 1 1 1 1 1 1 1 1 1.0 1 1.0 1) hex (19 23 27 28 4 8 12 13) (6 6 1) edgeGrading ( 1.0 1.0 1.0 1.0 1 1 1 1 1 1 1.0 1) hex (20 22 26 27 5 7 11 12) (5 3 1) edgeGrading ( 1.0 1.0 1.0 1.0 1 1 1 1 1 1.0 1 1.0) hex (9 10 14 13 24 25 29 28) (4 4 1) edgeGrading ( 1 1 1 1 1 1 1 1 1 1 1 1.0) ); boundary ( walls { type patch; faces ( (5 12 27 20) (11 6 21 26) (9 10 25 24) (13 12 27 28) (2 11 26 17) (13 9 24 28) (8 4 19 23) (12 8 23 27) (11 7 22 26) (14 13 28 29) (12 11 26 27) (6 0 15 21) (4 13 28 19) (7 5 20 22) ); } frontAndBack { type empty; faces ( (1 0 2 3) (6 11 2 0) (5 7 11 12) (4 8 12 13) (10 9 13 14) (16 18 17 15) (21 15 17 26) (20 27 26 22) (19 28 27 23) (25 29 28 24) ); } bottom { type patch; faces ( (1 3 18 16) (3 2 17 18) (0 1 16 15) ); } top { type patch; faces ( (10 14 29 25) ); } ); edges ( ); mergePatchPairs ( ); Code:
dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { top { type tractionDisplacement; traction uniform ( 0 -10000 0 ); pressure uniform 0; value uniform (0 0 0); } walls { type tractionDisplacement; traction uniform ( 0 0 0 ); pressure uniform 0; value uniform (0 0 0); } bottom { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } Thank you |
How to check Zone deformation? | raghu mohan | Fluent UDF and Scheme Programming | 0 | December 22, 2011 01:26 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Mesh deformation with InterDyMFoam.. gamma value problems.. | lostin4ever | OpenFOAM | 0 | June 18, 2010 01:55 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
