Moving contact line on solid object, OpenFoam
Hi All,
I don't know too much about OpenFoam and I need to ask a general question. I know OpenFoam can solve multiphase problems, the problem under my consideration is a moving solid object through a fluid-fluid interface. I need to define the contact angle when there is a fluid-fluid-solid contact line an this contact line may be moving as the solid is moving. I just want to know if OpenFoam can solve this problem before making any decisions to learn using it. I tried this problem in Gerris but turns out Gerris doesn't solve this kind of problem. Thank you for all your suggestions! Best, |
Well, without more detail about what kind of physics you require on the moving solid I am not sure how much work it will require on your part. There are solvers which can handle two-phase flow with a sharp fluid-fluid interface and a moving boundary. Check out the various tutorial cases for interDyMFoam. Hope that points you in the right direction.
-KW |
Actually I think the problem is simple. I just want to simulate a solid ball falling through a fluid interface and I believe a solver that deals with a sharp interface and moving contact line will be very helpful. Thanks for your suggestions! |
