CFD Quenching Model
Old   August 5, 2010, 10:28
Post CFD Quenching Model
Hamish Lewis
Hamish is on a distinguished road
I need to create a model of a super heated part, being submerged into Liquid to calculate the HTC's or the heat flux to put into a software for stress analysis. Does anyone have any insight into what solver to use for this, and if OpenFOAM can handle this? The part will be around 500-600 C and dropped into Oil at around 40 C. There are three phases of the transient problem. While it is being dropped into the fluid and for a very short time after, there will be a vapor film around the part, so the majority of heat transfer will be through radiation (and even conduction in the air), once this destabilizes then rapid boiling will occur. Finally the easy part is just cooling off through natural convection.
I think I might need to use multiple solvers and solve in three different phases, but I would like the software to predict when each phase is completed.
Thank you in advance for any advice.
Hamish
Hamish is offline   Reply With Quote
Old   October 3, 2010, 23:25
Default HTC calculation
CFDtoy
CFDtoy is on a distinguished road
Hi Hamish,
Take a look at this paper.
http://cat.inist.fr/?aModele=afficheN&cpsidt=22397140
If I am right AVL FIRE can do this. They have some more papers on this aspect. Check out googling their new features. Let me know if you are not able to figure it out.
Regards,
/CFDtoy
Hamish
CFDtoy
CFDtoy is offline   Reply With Quote
Old   October 4, 2010, 08:42
Hamish Lewis
Thank you, I'll check it out.
Old   March 4, 2014, 12:01
Default Quenching with OpenFOAM
michael157 is on a distinguished road
Thats a paper with AVL fire. Is there anything similar with openFOAM?
michael157 is offline   Reply With Quote
boiling modeling, multiphase boundary wall, quenching, rapid cooling
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
CFD of Model Aircraft Sashankh FLUENT 9 December 8, 2008 05:53
ASME CFD Symposium - Call for Papers Chris Kleijn Main CFD Forum 0 September 25, 2001 10:17
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
cfd model of a leaking valve?? stephen rosen Main CFD Forum 2 May 10, 1999 11:44
