Home > Forums > OpenFOAM
funkySetFields error
Old   March 12, 2014, 01:44
Default funkySetFields error
Sreetej
preacher is on a distinguished road
Greetings
I was trying initiate a Lamb-Oseen Vortex using funkySetFields command using :
funkySetFields -field U -keepPatches -expression 'U+((pos()-vector(50,47.1,pos().z))^vector(0,0,1))/mag(pos()-vector(50,47.1,pos().z))*(530/(2*pi*mag(pos()-vector(50,47.1,pos().z))))*(1-exp((-1/9)*sqr(mag(pos()-vector(50,47.1,pos().z))))))' -time 0
and it is showing me error.
I am running pimpleFoam model and the domain is a cuboid with uniform meshing. The error is as follows
Create time
Create mesh for time = 0
Time = 0
Using command-line options
Modifying field U of type volVectorField
Putting "U+((pos()-vector(50,47.1,pos().z))^vector(0,0,1))/mag(pos()-vector(50,47.1,pos().z))*(530/(2*pi*mag(pos()-vector(50,47.1,pos().z))))*(1-exp((-1/9)*sqr(mag(pos()-vector(50,47.1,pos().z))))))" into field U at t = "0" if condition "true" is true
Keeping patches unaltered
swak4Foam: Allocating new repository for sampledMeshes
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM FATAL ERROR:
Parser Error for driver FieldValueExpressionDriver at "1.189" :"syntax error, unexpected ')', expecting $end"
Context of the error:
- Driver constructed from scratch
Evaluating expression "U+((pos()-vector(50,47.1,pos().z))^vector(0,0,1))/mag(pos()-vector(50,47.1,pos().z))*(530/(2*pi*mag(pos()-vector(50,47.1,pos().z))))*(1-exp((-1/9)*sqr(mag(pos()-vector(50,47.1,pos().z))))))"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 1188.
FOAM exiting
Can anyone kindly suggest, how to sort out this problem..??
Thanks in advance..
Sreetej
preacher is offline   Reply With Quote
Old   March 12, 2014, 02:23
Sreetej
Sorry for the post, I got the solution there is a problem with the vortex equation parenthesis...
But i could not delete the thread, may be it's the settings of the forum.
Sorry again..
Thread Tools
Trackbacks are On
blockMesh with double grading. spwater OpenFOAM Native Meshers: blockMesh 85 October 11, 2015 09:03
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Saving ParaFoam views and case sail OpenFOAM Paraview & paraFoam 9 November 25, 2011 16:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
