Home > Forums > OpenFOAM
Lagrangian Boundary Condition (interstitialInletVelocity
Old   March 14, 2014, 03:27
Lightbulb Lagrangian Boundary Condition (interstitialInletVelocity
maysmech's Avatar
maysmech is on a distinguished road
Hello Foamers,
I have a question about interstitialInletVelocity inlet BC which is used in lagrangian/MPPIC/Goldschemidt testcase.
    bottom
        type            interstitialInletVelocity;
        inletVelocity   uniform (0 0 1.875);
        value           uniform (0 0 1.875);
        phi             phi.air;
        alpha           alpha.air;
What is its difference with fixedvalue in application?
in its .h description it says:
HTML Code:
Description
    Inlet velocity in which the actual interstitial velocity is calculated
    by dividing the specified inletVelocity field with the local phase-fraction.
To find its difference with uniformFixedValue I compared average magnitude of inlet velocity (By using Integration over bottom patch) and found that in fixedvalue (0 0 2) the average of inlet velocity is 2, But in interstitialInletVelocity of ( 0 0 2 ) the average velocity is 4.8 m/s.
I calculated average alpha.air magnitude in this patch = 0.42 and understood that 4.8 m/s=2.0/0.42 as described in .h file.
Seeing the contour of inlet in this condition shows the magnitude of air varies between 4 to 6.51 m/s with the average of 4.89 (is attached) and I don't know why it increases the stated 2 m/s to higher magnitudes. If it considers the solid fractions in inlet patch so it should be some zero magnitude velocities on inlet but there is not seen.
File Type: png value2-bottomContour-interstitialInletVelocity.png (13.1 KB, 20 views)
maysmech is offline   Reply With Quote
Old   March 23, 2014, 14:29
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Maysam,
If you take a look into the C file:
Originally Posted by src/finiteVolume/fields/fvPatchFields/derived/interstitialInletVelocity/interstitialInletVelocityFvPatchVectorField.C
void Foam::interstitialInletVelocityFvPatchVectorField::updateCoeffs()
    if (updated())
        return;
    const fvPatchField<scalar>& alphap =
        patch().lookupPatchField<volScalarField, scalar>(alphaName_);
    operator==(inletVelocity_/alphap);
    fixedValueFvPatchVectorField::updateCoeffs();
It essentially defines that the fixed boundary value for U at the inlet should be defined as "inletVelocity_/alphap". Therefore, this apparently assumes that:
  1. "inletVelocity_" is a reference velocity for a full "alphap" value, namely "1.0".
  2. "alphap" can never be zero, otherwise it would result in a crash with a SIGFPE: http://en.wikipedia.org/wiki/SIGFPE#SIGFPE
  3. The logic might be that the phase proportion is inversely proportional to the velocity, possibly due to a vacuum-like effect. I.e., when there is very little of this phase (smaller than 1.0), it acts as high-speed+low-pressure combination.
Best regards,
Bruno
Thread Tools
Trackbacks are On
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Domain Imbalance HMR CFX 3 March 6, 2011 21:10
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
