June 29, 2013, 10:56 |
laminar flow with heat transfer
Rep Power: 13 |
Hi everyone,
I have been trying simulate laminar flow with a constant heat flux through a cylindrical pipe. I have tried using buoyantBoussinesqSimpleFoam, buoyantBoussinesqPimpleFoam and even icoFoam with chnages in code. The buoyantSimple case is not converging and the other two cases are also not giving correct answers. I have used bc T- fixedGradient along wall to incorporate heat flux thing.... Can anyone suggest why the results are not coming correct?? Please, I am stuck with this one for two weeks....I need help.. Thanks in advance.... |
June 29, 2013, 15:44 |
Nima Samkhaniani
Rep Power: 24 |
what is your fluid?
why dont you use bouyantSimpleFoam?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
July 2, 2013, 02:34 |
Rep Power: 13 |
Hi nimasam,
My fluid is water, incompressible case. Also, I need to take into account gravity also. The solver which you are suggesting works for compressible fluids? |
July 2, 2013, 03:58 |
Nima Samkhaniani
Rep Power: 24 |
yes, it almost use for compressible fluid, but it can be used for incompressible fluid too , if you choose apropriate thermoPhydicalDict
However you choose some how suitable solvers, would you please, share your results in different solvers, and make much more declare why results are not correct
July 3, 2013, 04:57 |
#5 | |
Rep Power: 13 |
It has worked and I have got similar profiles but the magnitude is not correct. Like the maximum average velocity should have been 0.002 but it is coming out to be 0.0015 & similarly the expected temperature ranges were 307-338 but it is giving 301-334. I have checked the bc's. It looks correct to me. So, why it is so? |
July 3, 2013, 05:01 |
Nima Samkhaniani
Rep Power: 24 |
its damn close , maybe you need to play with ur numerical schemes forexample using second order schemes or refine your mesh
July 5, 2013, 04:04 |
Rep Power: 13 |
April 19, 2014, 09:25 |
Umut
Rep Power: 14 |
Hello good foamers,
I'm a new beginner in openfoam. I need to ask 2 questions. A)I'd like to solve a laminar channel flow in 2D. I'll use air as the working fluid and will use constant heat flux in one boundary. I tried to use buoyantBousinesqSimpleFoam but can't figure out how to arrange case files. Here is what I tried; 1) In RASProperties, I choose turbulence off and laminar as model. I deleted every variables in 0 folder except than p_rgh and copied the p,T,U files from my_icoFoam applications. 2) I used the same BCs for p_rgh as given in the iglooWithFridges tutorial by rearranging them to the geometry which I used. 3) The rest is the same with iglooWithFridges tutorial. I ran blockMesh without error. When I type buoyantBousinesqSimpleFoam in the terminal an error occurs concerning alphat. So how can I overcome this problem? B) Is there any standard solver to solve this problem transient? Kind Regards. Umut |
April 19, 2014, 09:33 |
#9 | |
Nima Samkhaniani
Rep Power: 24 |
April 19, 2014, 09:57 |
#10 |
Umut
Rep Power: 14 |
Dear nimasam;
Thank you for your reply, your suggestion worked just fine. I also found that buoyantBousinesqPimpleFoam works for transient flows. Kind regards, Umut Last edited by Umut; April 19, 2014 at 11:20. |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
