Any pipe (channel) flow tutorial by 'twoPhaseEulerFoam' in version 2.3.0?
Hi guys.
For solver 'twoPhaseEulerFoam' 2.3.0, a vertical fluidised bed case can be found in tutorial. However, if develop the case to a horizontal pipe with inlet and outlet BCs, I got apparently wrong results again and again, in both velocity and pressure. My question is, for the solver 'twoPhaseEulerFoam' 2.3.0, does anyone have a normal pipe flow case with good result? Really appreciate. |
Hi Xiangyin,
I am also interested to use 'twoPhaseEulerFoam" for a channel/pipe flow. I am still on the planning phase and didn't do any simulations except the tutorials which come with the solver. Let me know if you have got any progresses. Thanks, Getnet |
Hey guys,
Did you managed to get a twoPhaseEulerFoam example for a pipe flow? I've recently started to simulate a filling of a pipe containing air with polymer and solid particles using the multiphaseEulerFoam, a close brother of the twoPhaseEulerFoam. I used the typical boundary conditions for a internal flow simulation, but there's no phase movement whatsoever. |
Hey,
I would like to know if you had any success with simulations of channel/pipe flow usinf twophaseeulerfoam. Best regards, Daneish |
Um, maybe the fast way to adopt the tutorial to a pipe will be changing g vector.
