December 3, 2017, 22:31 |
The question about Fluent's mesh to OpenFOAM
LiangJian
Rep Power: 10 |
Dear All,
I want to transfer a Fluent's mesh to OpenFOAM, but I failed. I can not find the reason. I am a newer to OpenFOAM. my mesh is here: https://pan.baidu.com/s/1nvpBfDZ |
December 3, 2017, 22:33 |
You need to include the error message here, so that anyone can understand the problem you have.
__________________________ Implement what theory predict Ali Ikhsanul Qauli |
December 3, 2017, 23:23 |
LiangJian
Rep Power: 10 |
enginelab@enginelab:~/Desktop/zhangjiawen$ fluentMeshToFoam meshfile.msh
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : fluentMeshToFoam meshfile.msh Date : Dec 04 2017 Time : 11:12:39 Host : "enginelab" PID : 13061 Case : /home/enginelab/Desktop/zhangjiawen nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time number of faces: 204249 Number of points: 2794 Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading points FINISHED LEXING #0 Foam::error:rintStack(Foam::Ostream&) in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so" #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/bin/fluentMeshToFoam" #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 ? in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/bin/fluentMeshToFoam" Segmentation fault enginelab@enginelab:~/Desktop/zhangjiawen$ |
December 3, 2017, 23:27 |
LiangJian
Rep Power: 10 |
December 4, 2017, 06:42 |
Rep Power: 13 |
Is your mesh 2D or 3D?
December 4, 2017, 06:47 |
LiangJian
Rep Power: 10 |
December 4, 2017, 06:56 |
Rep Power: 13 |
ASCII or binary mesh file?
December 4, 2017, 07:20 |
LiangJian
Rep Power: 10 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 12:16 |
