wallHeatFlux compatibility to compute radiative flux |
July 2, 2014, 10:17 |
Alex
Rep Power: 21 |
Dear Foamers,
I would like to know how can I do to make wallHeatFlux utility takes into account the radiative heat flux, since I found out it doesn't by default. Is there any utility over there that can calculate the total heat flux (or even only the radiative part) as wallHeatFlux does with convective heat flux? My skills in C++ programming are quite weak for now so I would like to get accurate help in case I have to create and compile any application on my own. Many thanks in advance. Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
radiation flux, wallheatflux |
S2S yields oscillatory Radiative Heat Flux profiles | dennis.olivetree | FLUENT | 3 | September 11, 2015 11:40 |
Heat flux calculating with wallHeatFlux utility and alphaEff | tanshihaj | OpenFOAM Post-Processing | 0 | March 12, 2014 05:55 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
UDF for DOM recalling non-gray radiative heat flux | kaiyun | Fluent UDF and Scheme Programming | 0 | March 6, 2012 07:43 |
ratio of total heat flux and radiative heat flux | S.Karthikeyan | FLUENT | 2 | July 1, 2008 03:48 |
