interDyMFoam for surface waves of rotating propeller |
June 16, 2017, 08:57 |
Jiakun Wang
hello, everyone,
I am new to openFOAM and I'm trying to simulate the surface waves induced by rotating propeller underwater. With reference to the tutorials of propeller in pimpleDyMFoam and DTCHull in interDyMFoam, I made my case for simulation in the attachment. After the processes of snappyHexMesh and createPatch, it works fine while running "moveDynamicMesh". However, when I ran the interDyMFoam, the following mistake occured: Code:
Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone innerCylinderSmall PIMPLE: Operating solver in PISO mode Reading field p_rgh AMI: Creating addressing and weights between 23324 source faces and 46992 target faces AMI: Patch source sum(weights) min/max/average = 0.779747, 1.27884, 1.00016 AMI: Patch target sum(weights) min/max/average = 0, 1.02289, 0.50395 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST bounding k, min: 0 max: 0.00015 average: 0.00015 bounding omega, min: 0 max: 2 average: 2 kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Reading g Calculating field g.h No finite volume options present GAMG: Solving for pcorr, Initial residual = 1, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = nan, cumulative = nan Reading/calculating face velocity Uf Courant Number mean: nan max: nan Starting time loop Many thanks for all the help, I'm looking forward to it!! Best regards, |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Rotating propeller in a finite freestream velocity | asma | CFX | 9 | January 7, 2014 06:14 |
rotating propeller in stationary baffled vessel | wlt_1985 | FLUENT | 27 | March 30, 2011 01:22 |
Rotating Propeller | Nolin | FLUENT | 1 | September 6, 2006 23:07 |
propeller rotating at zero inflow velocity | Ammu | FLUENT | 1 | July 23, 2005 13:36 |
