Home > Forums > OpenFOAM
Like Tree1Likes
  • 1 Post By felicemastronzo
Old   September 3, 2014, 05:28
Default MRFInterFoam
felicemastronzo's Avatar
felicemastronzo is on a distinguished road
Dear all,
I have big problems in running a simulation using MRFInterFoam 2.3.0.
Actually the tutorial works fine, also by converting it in 3D.
The problem is that if I use a different geometry but with the same settings, I'm not able to run the simulation getting following error:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
All the U BC are fixedValue (0 0 0).
By changing one of the p_rgh BC from zeroGradient to fixexValue 0 it works but it make no sense! At least I'm not able to understand where the problem is.
PS: attached an example in which the mixtureVessel 3D tutorial works if no additional geometry is snapped in, while it gives problems if the additional geometry flange is introduces.
To run the tutorial
transformPoints -tanslate '(0 0 -0.01)'
snappyHexMesh -overwrite
JR22 likes this.
felicemastronzo is offline   Reply With Quote
Thread Tools
Trackbacks are On
Angular acceleration in MRFInterFoam 30na OpenFOAM Running, Solving & CFD 2 May 6, 2014 08:39
3Dmixer on simpleFoam and MRFInterFoam. sharonyue OpenFOAM Running, Solving & CFD 1 May 12, 2013 01:04
Boundary Conditions on MRFInterfoam edalmau OpenFOAM Running, Solving & CFD 0 April 23, 2013 13:32
MRFInterFoam JulytoNovember OpenFOAM Running, Solving & CFD 0 October 7, 2011 19:26
MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed bengt OpenFOAM Running, Solving & CFD 2 May 28, 2010 14:45
