Boundary Condition: Antisymmetric periodicity |
March 4, 2011, 09:16 |
Jacob Jensen
Has anyone come across boundary conditions in OpenFoam that impose anti-symmetric periodicity …
An anti-symmetric periodic boundary condition is just like periodic boundary conditions only swapped or mirrored … i.e. u(x, y)=u(x+L, ymax-y) v(x, y)=-v(x+L, ymax-y) p(x, y)=p(x+L, ymax-y) rather then (pure periodicity): u(x, y)=u(x+L, y) v(x, y)=v(x+L, y) p(x, y)=p(x+L, y) here u =velocity in x, v = velocity in y, p=pressure, x and y coordinates where y[0, ymax]. The boundary condition is described in “ON THE IMPLEMENTATION OF SYMMETRIC AND ANTISYMMETRIC PERIODIC BOUNDARY CONDITIONS FOR INCOMPRESSIBLE FLOW” by GUUS SEGAL, KEES VUIK AND KEES KASSELS. Last edited by Jacob Jensen; March 7, 2011 at 08:40. |
August 17, 2014, 05:35 |
Oleg Rogozin
Cyclic boundary conditions can be used in this case.
December 1, 2014, 12:28 |
Fredo
Rep Power: 11 |
yes they can, but then you need a cyclic geometry. Let me explain my case : I have a cubic domain which describe a porous media (liquid and solid). Only the liquid phase is meshed. Since the media is pretty random, the faces of my cube do not have the same mesh. To apply a cyclic boundary conditions (because that's what I want), I mirror the mesh in the x, y and finally z directions. I have then a cube 8 times bigger than my initial cube with all the same faces. I can then use cyclic boundary. But, I compute 7 times something I am not really interessted in. If I could apply antisymmetric periodicity, that would save a lot a time. Do you have any suggestions ? Fred. |
December 1, 2014, 16:32 |
Cyprien
Rep Power: 18 |
Hi Fredo,
What I do in this case: I had a thin layer of cells surrounding my domain. Like that I can impose cyclic boundary conditions. The two main problems when mirroring the domain: 1) it significantly increases the number of cells, 2) it biases the anisotropy (primordial for permeability estimation!). |
December 2, 2014, 03:29 |
Fredo
Rep Power: 11 |
Hi Cyp,
thank you for this quick reply. Your solution seems very relevant ! Did you quantify the errors induced by this thin layer. My media is not very percolating so I fear that all the fluid goes through this thin layer. I will try and keep you updated. Fred. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
Axis Boundary Condition..what is it? | CFDtoy | FLUENT | 6 | February 13, 2007 05:51 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
How to resolve boundary condition problem? | sam | FLUENT | 2 | July 20, 2003 02:19 |
