Error will loading makeAxialMesh utility in openFOAM-1.6
Like Tree1Likes
Old   February 24, 2010, 20:57
Default Error will loading makeAxialMesh utility in openFOAM-1.6
Patrick
will_avoid_comm_solvers is on a distinguished road
Greetings group members
I was trying to compile the makeAxialMesh utility and use it for generating an axi-symmetric mesh. I untarred the .gz file at this location
$HOME/OpenFOAM-1.6/applications/utilities/mesh//manipulation
Then i typed wmake in the command prompt. I am getting the following error
SOURCE=makeAxialMesh.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/patrick/OpenFOAM/OpenFOAM-1.6/src/dynamicMesh/lnInclude -I/home/patrick/OpenFOAM/OpenFOAM-1.6/src/cfdTools/lnInclude -I/home/patrick/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/patrick/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/patrick/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/makeAxialMesh.o
mkdir: cannot create directory `/home/patrick/OpenFOAM/patrick-1.6/applications': Permission denied
make: *** [/home/patrick/OpenFOAM/patrick-1.6/applications/bin/linuxGccDPOpt/makeAxialMesh] Error 1
++ echo -ne '\033]0;patrick@patrick-laptop: ~/OpenFOAM/OpenFOAM-1.6/applications/utilities/mesh/manipulation/makeAxialMesh\007'
I am pretty sure I am doing something wrong. Your help will be greatly appreciated. Also, is there any other way for creating axi-sym meshes in OpenFOAM or importing them from Gambit ?
will_avoid_comm_solvers is offline   Reply With Quote
Old   February 25, 2010, 09:09
Assistant Moderator
Bernhard Gschaider
You havn't compiled any utilities on that installation, have you (because that problem should occur with all of them). The problem is not with makeAxialMesh but with the permissions on your machine. You're not allowed to create the directory /home/patrick/OpenFOAM/patrick-1.6/applications (where the binary will be stored).
Bernhard
Old   February 25, 2010, 11:33
Patrick
Thanks Bernhard
I tried compiling few of existing utilities in /manipulation folder like attachMesh, subsetMesh etc. It works fine. One thing i noticed is that in the error message
All my openFOAM fiels are in /home/patrick/openFOAM/OpenFOAM-1.6/ directory, not in OpenFOAM/patrick-1.6 directory.
I do not know why it is trying to create folders in a different path. Do I have to change any environment variables?
Old   February 25, 2010, 12:44
Assistant Moderator
Bernhard Gschaider
Thanks Bernhard
All the utilities you mentioned got to $FOAM_APPBIN (because they're part of the distro) whilst makeAxialMesh goes to $FOAM_USER_APPBIN. The fact that you can write $FOAM_APPBIN but not $FOAM_USER_APPBIN ist strange (usually it's supposed to be the other way round - only a privileged user should be able to write to $FOAM_APPBIN). Try "mkdir $FOAM_USER_APPBIN" and see why you're not allowed to create this. Probably you're not allowed to create $WM_PROJECT_USER_DIR, try to get that fixed otherwise you won't have much fun with non-distribution stuff
Bernhard
Old   March 1, 2010, 13:44
Patrick
Thanks Bernhard
I was able to compile the makeAxialMesh utility. But I am getting a "floating point exception error" while running it. Here is the geometry i created using blockMesh
vertices
(0 0 -0.05)
(1 0 -0.05)
(1 1 -0.05)
(0 1 -0.05)
(0 0 0.05)
(1 0 0.05)
(1 1 0.05)
(0 1 0.05)
blocks
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
edges
patches
wall side_wall
(3 7 6 2)
patch inlet
(0 4 7 3)
patch outlet
(2 6 5 1)
empty center_ax
(1 5 4 0)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
Mesh was created succesfully. checkMesh gives no error. Here is the copy of the Boundary file.
5
side_wall
type wall;
nFaces 20;
startFace 760;
inlet
type patch;
nFaces 20;
startFace 780;
outlet
type patch;
nFaces 20;
startFace 800;
center_ax
type empty;
nFaces 20;
startFace 820;
frontAndBack
type empty;
nFaces 800;
startFace 840;
I changed the type for FrontAndBack from "Empty" to "Wedge". Then i ran the makeAxialMesh ("makeAxialMesh center_ax frontAndBack") I get this error
Build : 1.6-f802ff2d6c5a
Exec : makeAxialMesh center_ax frontAndBack
Date : Mar 01 2010
Time : 13:42:18
Host : crop-l.dese-lab.fda.gov
PID : 23132
Case : /home/pyh8/OpenFOAM/pyh8-1.6/cavity
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/pyh8/OpenFOAM/OpenFOAM-1.6
/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/lib/li
#2 __restore_rt at sigaction.c:0
#3 Foam::wedgePolyPatch::initTransforms() in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/
#4 Foam::wedgePolyPatch::wedgePolyPatch(Foam::word const&, Foam::dictionary con
st&, int, Foam:olyBoundaryMesh const&) in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/li
#5 Foam:olyPatch::adddictionaryConstructorToTable<F oam::wedgePolyPatch>::New(
Foam::word const&, Foam::dictionary const&, int, Foam:olyBoundaryMesh const&)
in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam:olyPatch::New(Foam::word const&, Foam::dictionary const&, int, Foam::
polyBoundaryMesh const&) in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOp
t/libOpenFOAM.so"
#7 Foam:olyBoundaryMesh:olyBoundaryMesh(Foam::IOo bject const&, Foam:olyMe
sh const&) in "/home/pyh8/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.
so"
#8 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/home/pyh8/OpenFOAM/Open
#9 main in "/home/pyh8/OpenFOAM/pyh8-1.6/applications/bin/linux64GccDPOpt/makeA
xialMesh"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 __gxx_personality_v0 in "/home/pyh8/OpenFOAM/pyh8-1.6/applications/bin/linu
x64GccDPOpt/makeAxialMesh"
Floating point exception
I am not sure what this means
Thanks
Patrick
Old   March 2, 2010, 12:57
Assistant Moderator
Bernhard Gschaider
Thanks Bernhard
I was able to compile the makeAxialMesh utility. But I am getting a &quot;floating point exception error&quot; while running it. Here is the geometry i created using blockMesh
I changed the type for FrontAndBack from &quot;Empty&quot; to &quot;Wedge&quot;. Then i ran the makeAxialMesh (&quot;makeAxialMesh center_ax frontAndBack&quot I get this error
You don't have to change that. The utility does that for you. Try again without changing (haven't got the time to reproduce the error, but I think this might be the problem)
Bernhard
Old   July 14, 2010, 23:24
Abdel
bruxellois4 is on a distinguished road
Dear Bernhard,
/opt/openfoam170/applications/utilities/mesh/manipulation
and when i try wmake i have this message
akeAxialMesh/makeAxialMesh$ wmake
mkdir: ne peut créer le répertoire `linuxGccDPOpt': Permission non accordée
/bin/sh: cannot create linuxGccDPOpt/options: Directory nonexistent
make: *** [linuxGccDPOpt/options] Erreur 2
/opt/openfoam170/wmake/MakefileFiles:39: linuxGccDPOpt/options: Aucun fichier ou dossier de ce type
make: *** Pas de règle pour fabriquer la cible « linuxGccDPOpt/options ». Arrêt.
wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created.
Can you help me please!
Thanks!
Abdel
bruxellois4 is offline   Reply With Quote
Old   July 15, 2010, 03:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by bruxellois4 View Post
Dear Bernhard,
Thanks!
Abdel
This is neither a problem with makeAxialMesh nor with OpenFOAM. You're trying to compile MAM in a place where you don't have write permissions.
I havn't tried MAM on 1.7 yet, but as it works with 1.6 I don't see why it shouldn't work
Bernhard
Old   July 15, 2010, 10:09
Abdel
Bernhard
If you don!t mind i've uploaded my case here http://www.4shared.com/file/Q3iXd22B/testtar.html
and i did as it is mentioned in openfoamwiki for makeAxialMesh, could you please apply the makeAxialMesh to it i really need that.
thanks
Abdel
Old   July 15, 2010, 16:26
Abdel
Dear Bernhard,
i've tried the same thing with openFoam1.6 but if i usde
./Allwmake
i got this message : ./Allwmake : 1: wmake not found
Any idea please.
Old   July 16, 2010, 05:13
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
./Allwmake
Any idea please.
If wmake is not found, then this is a pure problem with your OF-installation
Old   February 17, 2011, 09:05
Matthias Voß
mvoss is on a distinguished road
hi,
what is the FOAM_DEV_OPTION good for?
neewbie
mvoss is offline   Reply With Quote
Old   February 18, 2011, 06:56
Assistant Moderator
Bernhard Gschaider
Originally Posted by neewbie View Post
hi,
neewbie
A little bit more context would make it easier to answer such a question. Like "that is defined in Make/options" (I was tempted not to answer because if I need more time to UNDERSTAND the question than it took the asker to research/formulate the question, then I usually don't bother)
That option is needed so that the sources work with the OpenCFD-release as well as with the 1.5-dev/1.6-ext because they differ in the way meshes are manipulated.
Old   February 18, 2011, 07:30
Matthias Voß
sorry...
you´re right about the context, i should have added that.
the $(FOAM_DEV_OPTION) is in the the sources/Make/options-file of makeAxialMesh
what i did:
-tried to compile it against 1.6-ext
-->fatal error: repatch.H is missing
-against 1.6-ext without the FOAM_DEV_OPTION
--> fatal error: repatchPolyTopoChanger is missing
-give the absolute path to repatchPolyTopoChanger without the FOAM_DEV_OPTION
-->compiled and working without errors.
Since i know now that the FOAM_DEV_OPTION is for making the tool working with the different OF-distr. and i changed paths concerning that exact matter i know that there is smth. wrong on my side ... even if the tool is working now.
btw. echo $FOAM_DEV is giving 1 .... ???? that means smth. is wrong with my system/OF-variables ??!!
Thanks for the advice and the explanation of the FOAM_DEV option.
neewbie
Old   February 18, 2011, 09:25
Assistant Moderator
Bernhard Gschaider
sorry...
what i did:
neewbie
I THINK (can't verify that right now) the problem is that I havn't compiled it with 1.6-ext yet and in 1.6-ext some stuff concerning mesh-motion was moved to a different directory
Bernhard
Old   November 8, 2011, 10:19
Default changes compilation with OF1.6-ext
  #16
David P. Schmidt
schmidt_d is on a distinguished road
All:
I haven't looked at the source code for makeAxialMesh in a long time, but it looks like the issue is with the names (not just locations) of the header files changing. I just did a git pull this morning (Nov. 8th) of 1.6-ext and there is no repatch.H anywhere that I can see.
Here are the changes to makeAxialMesh/ that allow compilation (as generated by svn diff). Note that I turned off the FOAM_DEV option.
Index: makeAxialMesh.C
--- makeAxialMesh.C (revision 1921)
+++ makeAxialMesh.C (working copy)
@@ -51,7 +51,7 @@
#include "argList.H"
#include "Time.H"
#ifdef FOAM_DEV
-#include "repatch.H"
+#include "repatchPolyTopoChanger.H"
#else
#endif
Index: Make/options
--- Make/options (revision 1921)
+++ Make/options (working copy)
@@ -1,12 +1,13 @@
-ifdef FOAM_DEV
-FOAM_DEV_OPTION = -DFOAM_DEV
-endif
+//ifdef FOAM_DEV
+//FOAM_DEV_OPTION = -DFOAM_DEV
+//endif
EXE_INC = \
$(FOAM_DEV_OPTION) \
-I$(LIB_SRC)/dynamicMesh/lnInclude \
-I$(LIB_SRC)/cfdTools/lnInclude\
- -I$(LIB_SRC)/meshTools/lnInclude
+ -I$(LIB_SRC)/meshTools/lnInclude\
+ -I$(LIB_SRC)/dynamicMesh/dynamicMesh/lnInclude
EXE_LIBS = \
-ldynamicMesh \
With those changes, it worked for me.
-David
schmidt_d is offline   Reply With Quote
Old   October 20, 2014, 11:20
Default Problem with installation of makeAxialMesh on OF 1.6 ext
  #17
Mahdi
Masgar is on a distinguished road
Dear foamers,
I tried to install makeAxialMesh on OF-1.6-ext to have axisymmetric mesh, but there is an error in the process of making "makeAxialMesh":
user-1.6-ext//applications/bin/linux64GccDPOpt/makeAxialMesh/usr/bin/ld: cannot find -liberty
Could you please guide me if you have any experience with such an error?
Thanks and Best,
Mahdi
Masgar is offline   Reply With Quote
Old   October 20, 2014, 13:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by Masgar View Post
Dear foamers,
Thanks and Best,
Mahdi
Your system is missing a library called libiberty.so
Don't know which package installs that. Google for it and then install that package
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 20, 2014, 17:49
Mahdi
Thanks a lot Bernhard for the reply.
I checked for the package, it is mentioned to be "benutlis-dev" or "gcc", but when I tried to install them, it turned out they are both already installed!
I am using Ubuntu 14.04, if it affects the installation procedure.
I would be grateful to have your opinion in this regard,
Best,
Mahdi
Old   October 21, 2014, 04:40
Assistant Moderator
Bernhard Gschaider
Best,
Mahdi
I HAVE an opinion concerning Ubuntu but you won't be grateful to hear it
Seriously: I have no Ubuntu so I can't help you there. Wonder how anything got compiled on your machine without that library
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 18:04
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 02:00
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 0 February 5, 2010 12:12
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
