initial residuals in icoFoam
Like Tree1Likes
  • 1 Post By Tushar@cfd
Old   December 12, 2014, 08:55
Default initial residuals in icoFoam
Sami
Mehrez is on a distinguished road
My question is about the icoFoam solver (used for transient incompressible Newtonian fluids). Does someone know how the initial residual is evaluated ? I mean the equation.
Thank you in advance.
Mhrz
Mehrez is offline   Reply With Quote
Old   December 13, 2014, 02:29
T. Chourushi
Tushar@cfd is on a distinguished road
Have a look at the following post, where you will find that L1 norm is used.
http://www.cfd-online.com/Forums/ope...tml#post299291
Best Regards!
Mehrez likes this.
Tushar@cfd is offline   Reply With Quote
Old   December 14, 2014, 13:24
Exclamation
Sami
Best Regards!
Thank you for this answer.
It is mentioned on the OpenFoam doc that "the residual is evaluated by substituting the current solution into the equation and taking the magnitude of the difference between the left and right hand sides".
So if I understand well, from the PCG.C file where
solverPerf.initialResidual() = gSumMag(rA)/normFactor
The (rA) is the difference between the left and right hand sides of the equation to solve ?
If we consider the IcoFoam solver. At which step of the PISO algorithm the residual is computed ?
You can see here the numbered equations :
https://www.dropbox.com/s/m848engmee4qawy/Algo.pdf?dl=0
Can you please based on the this file tell me the complete formula of the residual ?
Thanks in advance !
Mhrz
icofoam, openfoam, residuals
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
