Home > Forums > OpenFOAM
Create patches from a very complex geometry
Like Tree1Likes
  • 1 Post By fabian_roesler
Old   January 8, 2015, 06:56
Post Create patches from a very complex geometry
Julie Correncon
CoSponge is on a distinguished road
Hello everybody,
I am wondering if it is possible to create patches and different region automatically from a .stl file.
For a simple geometry I tried to isolate the faces belonged to the different regions I'd like to have in the .stl file manually. It works perfectly
But now I have a very complex geometry, isolating the region is impossible by hand.
AutoPatch doesn't work, because it isolates some single points as a region (the mesh is not perfect) or the whole geometry, depending on the angle.
I know I could do it with the tool createPatches or making different blockMesh regions for each patch.
Does anyone knows the best option??
Thanks in avdance for the help,
Julie
CoSponge is offline   Reply With Quote
Old   January 9, 2015, 02:46
Default surfaceToPatch
fabian_roesler's Avatar
Fabian Roesler
fabian_roesler is on a distinguished road
Have you tried surfaceToPatch? With this tool you can identify faces close to a stl surface and automatically create a path out of them.
Cheers
Fabian
fumiya likes this.
fabian_roesler is offline   Reply With Quote
Old   January 12, 2015, 05:23
Default Error
Julie Correncon
Hey Fabian,
thank you a lot for your reply
I've tried, but I got this error:
Create time
Create polyMesh for time = 0
Reading surface from "pipe.stl" ...
Patching all boundary faces according to nearest surface triangle ...
All boundary faces further away than 0.001 of mesh bounding box (-0.04 -0.2 -0.15) (0.04 0.04 0.2) will keep their patch label ...
Before patching:
patch size
defaultFaces 34385
--> FOAM FATAL ERROR:
Cannnot read "pipe.stl"
From function triSurface::read(const fileName&, const word&, const bool)
in file triSurface/triSurface.C at line 369.
FOAM exiting
I should apply surfaceToPatch after snappyHexMesh, right?
Thanks in advance for the help,
greetings
Julie
Old   January 13, 2015, 03:32
Default check the tutorials
Fabian Roesler
When you're using snappy you can follow the chtMultiRegionFoam tutorials. They describe how to produce a multi region mesh with snappy. The basic work flow is the following:
  1. Create a single region mesh with cellZone for each region you want to create
  2. Run splitMeshRegions on the mesh (this will create the multi region mesh)
  3. Run changeDictionary to set the initial and boundary conditions for the regions
  4. Run the case
Cheers
Fabian
complex geometry, patches, regions, stl file
Thread Tools
Trackbacks are On
[ICEM] Create geometry (iges or step file) from fluent mesh muketa ANSYS Meshing & Geometry 10 August 5, 2015 05:38
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 14 July 25, 2015 14:15
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) fluent_beiyo ANSYS Meshing & Geometry 8 April 26, 2014 04:55
[ICEM] How to deal with a really complex geometry mountaineer ANSYS Meshing & Geometry 1 February 21, 2012 12:57
Include list of points Hikachu OpenFOAM Native Meshers: blockMesh 0 June 20, 2011 09:03
