January 12, 2015, 09:16 |
3d multiPhaseEulerFoam error
Hamzeh
Rep Power: 11 |
I wanna run my case but an error appear in first time step:
Courant Number mean: 0.00205988 max: 0.00490449 Time = 0.01 MULES: Solving for alpha.oil oil volume fraction, min, max = 0 0 1 MULES: Solving for alpha.water water volume fraction, min, max = 1 0 1 Phase-sum volume fraction, min, max = 1 0 1.5 MULES: Solving for alpha.oil oil volume fraction, min, max = 0 0 1 MULES: Solving for alpha.water water volume fraction, min, max = 1 0 1 Phase-sum volume fraction, min, max = 1 0 1.5 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 Foam::multiphaseSystem::nu() const at ??:? #6 Foam::incompressible::LESModels::laminar::nuSgs() const at ??:? #7 Foam::incompressible::LESModel::nut() const at ??:? #8 at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 at ??:? Floating point exception (core dumped) whats the problem? |
January 12, 2015, 10:36 |
Nima Samkhaniani
Rep Power: 24 |
turn off turbulence and run your case again , it seems it relates to your turbulence setup
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
January 13, 2015, 11:34 |
Hamzeh
Rep Power: 11 |
thank you,
my lesmodel is laminar. how can I turn off turbulence? |
January 20, 2015, 15:21 |
Kent Wardle
Rep Power: 21 |
Looks to me like something might be wrong with your initialization of the alpha fields. Why does the phase sum show 1.5? Are you sure everything is consistent? It is not exactly failing due to turbulence, but rather when calculating the mixture viscosity nu() for the turbulenceModel--which it will use in either case for laminar or turbulent. Check your initialization.
January 21, 2015, 02:31 |
Hamzeh
Rep Power: 11 |
Thank you for your response ,
It fixed by setFields and as you truly mentioned void fraction was not consistent.However, my new problem is that my case is 3d and I wanna view 3d output but dispersed phase dont enter in inner domain and only dispersed in boundaries.You can view my case in link below : http://www.cfd-online.com/Forums/ope...eulerfoam.html |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
