How to create a new case for a real design problem?
Hi all,
Everyone has explained how to solve the things which is already in the tutorials(i.e., cavity, elbow are already documented with the folders '0', 'constant', and 'system') Now i have a design and i want to make the document with the folders as required. please help me.. |
Please, describe your problem more elaborately if you need help from the forum (http://www.cfd-online.com/Forums/ope...-get-help.html)
Cheers shakil |
Hi shakil,
For example, Now I have designed a drawing in freecad it is related to flow of water from reservoir1 to reservoir2, both of them are structured at the top ends of a 'l_l' shaped pipe. i have placed a nozzle in the horizontal pipe(Play pipe). Now i want to simulate and want to how the flow fluid behaves. How to create the case folders containing the '0', 'constant' and 'system' folder to run the simulation. |
Cheers shakil |
nice document, went through each node of the document, found informative. My another question is before running the $Foam_tutorials, I should make the meshing in salome or any other FEA tool, after meshing we have to save the file in UNV format, after creating the format of file at this point we have to make the supporting folders('0', 'constant', 'system') of this document so that this file will save in the tutorial folder so the corresponding case folder for this example can be created so that this can be read by OpenFOAM. How to create that case folder after meshing my drawing? |
