Looking for 3D openfoam case file of wind flow over a tall building
Old   January 29, 2015, 04:15
Default Looking for 3D openfoam case file of wind flow over a tall building
arya
arya123 is on a distinguished road
I need a 3D case file of wind flow over a tall building in OpenFoam.
I hope somebody can help me.
arya123 is offline   Reply With Quote
Old   February 6, 2015, 04:32
Elvis
elvis will become famous soon enough
you should have searched in the wiki http://openfoamwiki.net
http://openfoamwiki.net/index.php/Ma...banAreaNiigata
http://openfoamwiki.net/index.php/Ma...ngInCityBlocks
http://openfoamwiki.net/index.php/Main_ContribExamples
if the examples from our friends in Japan do not help you
you might search at the "wind energie" people or HVAC people stuff
elvis is offline   Reply With Quote
Old   February 9, 2015, 06:02
arya
thank you elvis.
I went through the links you have given and tried some cases. But I used to shift from one to another when errors comes, which I was unable to rectify.
Can you help me in one of the case I have downloaded and tried.
The blockMeshDict file for the case is as given below.
convertToMeters 1.0;
vertices
( -0.4 0.28 0 )
( -0.02 0.28 0 )
( 0.02 0.28 0 )
( 0.96 0.28 0 )
( -0.4 0.02 0 )
( -0.02 0.02 0 )
( 0.02 0.02 0 )
( 0.96 0.02 0 )
( -0.4 -0.02 0 )
( -0.02 -0.02 0 )
( 0.02 -0.02 0 )
( 0.96 -0.02 0 )
( -0.4 -0.28 0 )
( -0.02 -0.28 0 )
( 0.02 -0.28 0 )
( 0.96 -0.28 0 )
( -0.4 0.28 0.392 )
( -0.02 0.28 0.392 )
( 0.02 0.28 0.392 )
( 0.96 0.28 0.392 )
( -0.4 0.02 0.392 )
( -0.02 0.02 0.392 )
( 0.02 0.02 0.392 )
( 0.96 0.02 0.392 )
( -0.4 -0.02 0.392 )
( -0.02 -0.02 0.392 )
( 0.02 -0.02 0.392 )
( 0.96 -0.02 0.392 )
( -0.4 -0.28 0.392 )
( -0.02 -0.28 0.392 )
( 0.02 -0.28 0.392 )
( 0.96 -0.28 0.392 )
blocks
hex (4 5 1 0 20 21 17 16) (29 19 59) simpleGrading (0.05 20 1)
hex (5 6 2 1 21 22 18 17) (21 19 59) simpleGrading (1 20 1)
hex (6 7 3 2 22 23 19 18) (73 19 59) simpleGrading (20 20 1)
hex (8 9 5 4 24 25 21 20) (29 21 59) simpleGrading (0.05 1 1)
hex (10 11 7 6 26 27 23 22) (73 21 59) simpleGrading (20 1 1)
hex (12 13 9 8 28 29 25 24) (29 19 59) simpleGrading (0.05 0.05 1)
hex (13 14 10 9 29 30 26 25) (21 19 59) simpleGrading (1 0.05 1)
hex (14 15 11 10 30 31 27 26) (73 19 59) simpleGrading (20 0.05 1)
edges
arc 5 6 ( 0 0.02 0 )
arc 6 10 ( 0.02 0 0 )
arc 9 10 ( 0 -0.02 0 )
arc 9 5 ( -0.02 0 0 )
arc 21 22 ( 0 0.02 0.392 )
arc 26 22 ( 0.02 0 0.392 )
arc 25 26 ( 0 -0.02 0.392 )
arc 25 21 ( -0.02 0 0.392 )
patches
wall walls
(5 21 22 6)
(6 22 26 10)
(10 26 25 9)
(9 25 21 5)
patch inlet
(4 20 16 0)
(8 24 20 4)
(12 28 24 8)
patch outlet
(3 19 23 7)
(7 23 27 11)
(11 27 31 15)
wall sides
(16 17 1 0)
(17 18 2 1)
(18 19 3 2)
(12 13 29 28)
(13 14 30 29)
(14 15 31 30)
wall lowerUpper
(0 1 5 4)
(1 2 6 5)
(2 3 7 6)
(4 5 9 8)
(6 7 11 10)
(8 9 13 12)
(9 10 14 13)
(10 11 15 14)
(20 21 17 16)
(21 22 18 17)
(22 23 19 18)
(24 25 21 20)
(26 27 23 22)
(28 29 25 24)
(29 30 26 25)
(30 31 27 26)
mergPatchPairs
Here we get a building that extends from bottom to top of the boundary. I need to change this geometry such that the building height must be reduced (top side of the building shouldn't touch the boundary) so that I can simulate a flow over the building.
Can you show me how to change this case file for that ?
thanks in advance.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
