How to simulate the flow of the particles (like sand) inside a pipeline? |
January 29, 2015, 09:00 |
libo
Rep Power: 11 |
hi,all
i want to simulation the flow of the particles(like sand) in pipeline,but i don`t konw how to do this use openfoam(I'm learning openfoam for three days ). please give me some advice or example thank you! |
February 5, 2015, 10:23 |
Ramon
Rep Power: 12 |
Hello libo,
There are various options I think to do this, perhaps I am not even mentioning all of them. There is a Two Fluid Model in OpenFOAM (called twoPhaseEulerFoam) which has tutorial cases for a fluidized bed, which is quite close to the application you are asking for (gas-solid flow). You could use this to simulate solids flow, you just have to change the domain a little bit and your boundaries. The disadvantage of this solver is that the theory behind the solids flow and rheology (Kinetic Theory of Granular Flow) is not very easy to understand on a fundamental level. Also there are lagrangian solvers like DPMFoam and MPPICFoam that simulate the solids phase as parcels. I guess this comes closer to 'real' gas-solid systems. I do not know a lot about these solvers though. Finally, there is something called LIGGGHTS and CFDEM; LIGGGHTS is a Discrete Element Method package and CFDEM is the LIGGGHTS package coupled with OpenFOAM (which calculates the gas flow part). See the link: http://www.cfdem.com/about-cfdemrproject Hope this helps a little bit. First make sure you have some experience with the most basic tutorials such as damBreak and cavity. Kind regards, Ramon |
February 5, 2015, 21:04 |
libo
Rep Power: 11 |
Dear Ramon,
Thanks for your reply.I`m so sorry,I did not descripbe my problem very clearly.I don`t want to simulate gas-solid flow.I want to simulate liquid-solid flow(some solid particle flow in the oil pipeline).I have been use the fluent-edem but my teacher wants me find other software to sovle this problem. I have been read a literature ,the lagrangian solvers don`t consider the force to particle-particle,we need program the code by ourselves(the author use the Discrete Element Method).I think is too difficult for me.Is there some model about drag force,Magnus force,Saffman force in OpenFOAM? Thank you so much! LiBo |
February 6, 2015, 03:49 |
Ramon
Rep Power: 12 |
I think solid-liquid flow should as well be possible with CFDEM, see this link:
http://web.student.chalmers.se/group...SlidesOFW5.pdf Also the forces you have mentioned should be in the model (I have not checked this myself though). I am not sure whether these forces are also in an OpenFOAM model, I know there is no particle rotation force in twoPhaseEulerFoam for example, but I am not sure about the other two models I have mentioned. You can always look into the source codes of the solvers I have mentioned in the applications/solvers/ folder, then you can see which forces have been taken into account. Programming your own DEM or DPM code is quite time consuming, it is even difficult to do this properly within a full PhD project (I have some experience with this...). Keep in mind that when modeling oil-solid flow that most flow solvers do not take the non-Newtonian behavior of the oil into account. Either you will have to edit the flow solver and mess around with the stress tensors, or you have to use a non-Newtonian solver and implement the fluid-particle interactions (which sounds like more work to me). Kind regards, Ramon |
February 6, 2015, 06:03 |
libo
Rep Power: 11 |
Thanks you again.
LiBo |
February 8, 2017, 00:13 |
Solid Flow
Deepak Kumar
I want to simulate the solid flow inside the Iron blast Furnace . I have to take care of only solid nothing else . so is there any Solver there for solid flow simulation . Please help me .
May 23, 2017, 03:14 |
Error with DPM
Hi. I have a problem. I used DPM solver for my project .First i changed the blockMesh without changing the kinematic cloud pisition file ,then changing the kinematic cloud pisition file without changing the blockmesh. For both of them the error is "Cannot find parcel injection cell".Please help me.
Both of work were attached. |
November 1, 2017, 08:51 |
Rep Power: 8 |
May be too late for you m_snjri but I'll anwer that:
In the blockMesh-file you have the convertToMeters option before defining the vertices. This could make the dimension of your whole Mesh too small. A second one, which is more likely, is your negative values in the kinematicCloudPosition file. Your blockMesh is not defined for those (60x10x50). |
April 18, 2018, 17:52 |
#9 | |
Min Zhang
Rep Power: 9 |
Hello LiBo, How is going of your simulations? Which software are you using right now? This is Min, I am at the beginning to use MPPICFoam/DPMFoam to simulate proppant transport in wellbores, which is very similar to your project. So I am wondering whether you could give me some suggestions. Thanks and best regards, Min |
July 3, 2018, 02:13 |
fluent edem add-in
#10 |
hi dears,
I want to couple fluent and edem and for that purpose I need an add-in which by installing it and make new tab named edem in ansys workbench let me couple these software dose anyone help me with these add-in because I can't download it from main website. best regard. |
July 17, 2018, 02:45 |
water flow over a sand bed
#11 |
Ainal Hoque Gazi
Rep Power: 7 |
Hi everyone
i want to simulation the flow over particles(like sand) in rive.Please suggest me which solver i should use in openFoam for that. Thanks and regards |
July 17, 2018, 03:19 |
#12 | |
Robert
Rep Power: 11 |
do you mean "over particles" as in "over one or more fixed particles that a not moving"? Then simply use OpenFoam in conjunction with a hydrodynamic transient solver (piso, pimple). Create the numerical domain using blockMesh and an .stl file representing your shape in snappyHexMesh. If "over particles" means "flow with moving particles at the bottom", than go ahead and use CFDEM and Liggghts. Still requires OpenFOAM to simulate the fluid properties, but CFDEM/Liggghts will take care of the particle movement and the particle interactions.
If you liked my answer to your question, please consider leaving a "Like" in return |
July 17, 2018, 05:46 |
#13 | |
Ainal Hoque Gazi
Rep Power: 7 |
Thanks Robert for your quick reply...sorry for not giving details of my problem.Actually i have made the geometry in blockMeshDict.it is a scouring problem.like flow past a cylinder case.so for scouring i need sediment bed and that will be flow with moving particles at the bottom i think....will twoPhaseEulerFoam can do this?Thanks and regards |
July 17, 2018, 05:58 |
#14 |
Robert
Rep Power: 11 |
A colleague of mine uses OpenFOAM and CFDEM/Liggghts to simulate the movement of grains over sand ripples. So i think the software should be applicable to your scour simulation. I face i would go with the coupled approach in contrast to using a multiphase solver.
July 17, 2018, 09:29 |
#15 | |
Ainal Hoque Gazi
Rep Power: 7 |
Regards |
December 13, 2018, 17:48 |
#16 | |
tooran
Rep Power: 9 |
I did not know how i shoudl do it. please give me some advice thanks |
December 14, 2018, 04:18 |
#17 | |
Robert
Rep Power: 11 |
January 2, 2019, 14:18 |
#18 | ||
tooran
Rep Power: 9 |
Thanks Can you help me please? Last edited by wyldckat; January 27, 2019 at 15:31. Reason: merged posts a minute apart |
January 7, 2019, 03:52 |
#19 |
Robert
Rep Power: 11 |
Sounds like, the simulation is working and the problem is your paraview. If you post the error wich appears when typing "parafoam" somebody may be able to help you. But not without knowing what exactly is wrong.
March 4, 2019, 07:32 |
#20 | |
Esmaeel
Rep Power: 13 |
Is it possible to simulate the turbulent flow of gas and solids inside a pipe with openfoam? Since it's turbulent flow, the cell size near to wall should be very small and it's less than particle size. How openfoam deal with it when calculating void fraction in each cell? in other words, can a cell size be smaller than particle size in openfoam? I would really appreciate if you could help me with this problem. Thanks Esi |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
DPM for steady flow with unsteady particles tracking | yahya | FLUENT | 0 | March 28, 2013 13:28 |
Simulate solid particles in compressible gas flow | CYMa | OpenFOAM | 2 | February 16, 2011 19:39 |
velocity of massless particles and velocity of flow field in same coordinate | payam_IUST | FLUENT | 0 | October 18, 2009 23:24 |
spherical particles in a flow stream | Adolfo Menendez | Main CFD Forum | 3 | September 3, 1998 15:13 |
