Convergence with Simplefoam
Old   March 11, 2015, 11:32
Default Convergence with Simplefoam
Rubén
Yuby is on a distinguished road
Hi Foamers!
I don't know why, but I am having big problems in my case. I don't know why but simplefoam don't converges. I changed the relaxation factors, did the checkMesh... And it doesn't works!
With a diferent type of refinement I obtain a converged solution, but with this refinement not. And checkMesh says that my mesh is OK as you can see. I don't knwo really what to do ! I put bounded Gauss upwind schemes for every variable, I think it's the best in this case.
I attach my log file an some files more! I will be pleased for every answer... I'm a bit desesperate
Thank you very much in advance!
End of log fie:
Time = 893
smoothSolver:  Solving for Ux, Initial residual = 0.202157, Final residual = 0.0112941, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.515388, Final residual = 0.0439188, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.380651, Final residual = 0.00752332, No Iterations 1
GAMG:  Solving for p, Initial residual = 1.18088e-07, Final residual = 6.93975e-08, No Iterations 1
time step continuity errors : sum local = 2.89175e+12, global = -4.73148e+10, cumulative = -4.73148e+10
smoothSolver:  Solving for epsilon, Initial residual = 2.37023e-10, Final residual = 2.37023e-10, No Iterations 0
smoothSolver:  Solving for k, Initial residual = 0.263584, Final residual = 0.00591683, No Iterations 1
bounding k, min: -5.67569e+30 max: 4.98836e+36 average: 5.91692e+31
ExecutionTime = 4970.94 s  ClockTime = 5152 s
Time = 894
smoothSolver:  Solving for Ux, Initial residual = 0.202334, Final residual = 0.00481158, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.205201, Final residual = 0.0113306, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0962262, Final residual = 0.00346977, No Iterations 2
GAMG:  Solving for p, Initial residual = 1.12762e-18, Final residual = 1.12762e-18, No Iterations 0
time step continuity errors : sum local = 1.3093e+59, global = -9.35364e+42, cumulative = -9.35364e+42
smoothSolver:  Solving for epsilon, Initial residual = 6.84338e-11, Final residual = 6.84338e-11, No Iterations 0
bounding epsilon, min: 1.39235e-19 max: 3.27976e+57 average: 6.52687e+51
smoothSolver:  Solving for k, Initial residual = 0.87113, Final residual = 0.042468, No Iterations 1
bounding k, min: -7.32165e+31 max: 1.33669e+51 average: 3.71993e+45
ExecutionTime = 4974.96 s  ClockTime = 5156 s
Time = 895
smoothSolver:  Solving for Ux, Initial residual = 8.65286e-09, Final residual = 8.65286e-09, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 3.91018e-10, Final residual = 3.91018e-10, No Iterations 0
smoothSolver:  Solving for Uz, Initial residual = 2.95985e-08, Final residual = 2.44359e-09, No Iterations 1
GAMG:  Solving for p, Initial residual = 1.27174e-20, Final residual = 1.27174e-20, No Iterations 0
time step continuity errors : sum local = 6.53034e+56, global = -3.47895e+40, cumulative = -9.38843e+42
smoothSolver:  Solving for epsilon, Initial residual = 2.62477e-07, Final residual = 1.58738e-08, No Iterations 2
bounding epsilon, min: -5.52704e+76 max: 4.64178e+77 average: 1.9647e+72
smoothSolver:  Solving for k, Initial residual = 0.0205769, Final residual = 0.0011484, No Iterations 3
bounding k, min: -6.71005e+39 max: 7.39668e+60 average: 1.24645e+55
ExecutionTime = 4979.05 s  ClockTime = 5160 s
Time = 896
smoothSolver:  Solving for Ux, Initial residual = 0.98904, Final residual = 0.0714643, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.996664, Final residual = 0.0839625, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.616932, Final residual = 0.0181629, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.0991486, Final residual = 1.02504e-05, No Iterations 1
time step continuity errors : sum local = 1.2079e+57, global = 5.15769e+41, cumulative = -8.87266e+42
checkMesh file:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : checkMesh
Date   : Mar 11 2015
Time   : 17:27:58
Host   : "usuario-SATELLITE-P50-A-14G"
PID    : 6239
Case   : /home/usuario/Frisbees/Cilindro/DiscraftUltraStar_kepsilon_0.1vr
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            10206962
    internal faces:   10062872
    cells:            3308975
    faces per cell:   6.12571
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     3059355
    prisms:        12075
    wedges:        0
    pyramids:      0
    tet wedges:    58
    tetrahedra:    0
    polyhedra:     237487
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   11685
            5   7717
            6   17983
            7   84921
            8   25746
            9   75748
           10   150
           11   17
           12   8944
           15   4552
           18   24
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
                   inlet       76       97  ok (non-closed singly connected)
                  outlet       64       81  ok (non-closed singly connected)
                     top       96      117  ok (non-closed singly connected)
                  bottom       96      117  ok (non-closed singly connected)
            frontandback      192      234  ok (non-closed singly connected)
                 frisbee   143566   155426      ok (closed singly connected)
Checking geometry...
    Overall domain bounding box (-1.5 -2 -2) (4.5 2 2)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-7.91179e-17 1.45473e-17 -1.85313e-18) OK.
    Max cell openness = 4.42999e-16 OK.
    Max aspect ratio = 7.52203 OK.
    Minimum face area = 7.81257e-08. Maximum face area = 0.250442.  Face area magnitudes OK.
    Min volume = 3.23513e-11. Max volume = 0.125241.  Total volume = 95.9998.  Cell volumes OK.
    Mesh non-orthogonality Max: 64.9948 average: 6.55222
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.24885 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
fvSolutions:
|  \\    /   O peration     | Version:  2.3.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.01;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration on;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels     1;
    "(U|k|epsilon|R|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-08;
        relTol          0.1;
	nSweeps		1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-8;
        U               1e-8;
        "(k|epsilon|omega)" 1e-8;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        epsilon         0.7;
        R               0.7;
        nuTilda         0.7;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,R)      bounded Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Yuby is offline   Reply With Quote
Old   March 11, 2015, 11:38
Rubén
completeAnd, of course, my 0.org with properties calculated with http://www.cfd-online.com/Tools/turbulence.php for a eddy viscosity ratio of 0.1
k:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
#include        "include/initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $turbulentKE;
boundaryField
     inlet
        type            fixedValue;
        value           uniform $turbulentKE;
    outlet
        type            zeroGradient;
    frisbee
        type            kqRWallFunction;
        value           $turbulentKE;
    #include "include/frontBackUpperPatches"
epsilon:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform $turbulentEpsilon;
boundaryField
    inlet
        type            fixedValue;
        value           uniform $turbulentEpsilon;
    outlet
        type            zeroGradient;
    frisbee
        type            epsilonWallFunction;
U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    #include "include/fixedInlet"
    outlet
        type            zeroGradient;
    frisbee
	type rotatingWallVelocity;
	origin (0 0 0);
	axis (0 0 -1);
	omega $omegadisk;
p:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform $pressure;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    frisbee
        type            zeroGradient;
fixedInlet:
inlet
    type  fixedValue;
    value uniform $flowVelocity;
frontBackUpperPatches:
top
    type slip;
bottom
    type slip;
frontandback
    type slip;
initialConditions:
flowVelocity         (16 0 0);
omegadisk	     37.7;
pressure             0;
turbulentKE          0.0096;
turbulentEpsilon     5.5296;
#inputMode           merge
Old   March 18, 2015, 05:00
JNSN's Avatar
Jan
JNSN is on a distinguished road
Try to use a MRF zone around your frisbee.
Regrads,
Jan
JNSN is offline   Reply With Quote
Convergence and steady state using simpleFoam sfigato OpenFOAM Running, Solving & CFD 0 February 8, 2013 04:14
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence Problems SimpleFOAM Kutti OpenFOAM 16 June 14, 2010 08:12
Getting faster convergence in simpleFoam basneb OpenFOAM 8 February 9, 2010 04:20
Definition of convergence criterion in simpleFoam titio OpenFOAM Running, Solving & CFD 1 February 6, 2010 01:34
