March 27, 2015, 09:59 |
twoPhaseEulerFoam error message
Rep Power: 11 |
Trying to chase down an error and am wondering if anyone has run into this issue before. I am simulating a 3D cylindrical fluidized bed using twoPhaseEulerFoam (parallel run using 24 processors) and have received the following stack using both the Gidaspow and SyamlalOBrien drag models:
[19] #0 Foam::error::printStack(Foam::Ostream&) in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [19] #1 Foam::sigFpe::sigHandler(int) in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [19] #2 [19] at sigaction.c:0 [19] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [19] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) $ [19] #5 Foam::dragModels::SyamlalOBrien::CdRe() const in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleEulerianInterfacialModels.so" [19] #6 Foam::dragModel::K() const in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleEulerianInterfacialModels.so" [19] #7 Foam::RASModels::kineticTheoryModel::correct() in "/home/naccarato.a/OpenFOAM/naccarato.a-2.3.1/platforms/linux64GccDPOpt/lib/libphaseCompressibleTurbulenceModels.so" [19] #8 Foam::twoPhaseSystem::correctTurbulence() in "/shared/apps/openfoam/openfoam-2.3.1/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleTwoPhaseSystem.so" [19] #9 [19] in "/home/naccarato.a/OpenFOAM/naccarato.a-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" [19] #10 __libc_start_main in "/lib64/libc.so.6" [19] #11 [19] in "/home/naccarato.a/OpenFOAM/naccarato.a-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" |
March 27, 2015, 20:02 |
Rep Power: 11 |
Some additional information:
I can get my case to run with coarser meshes. As I try to refine the mesh I see the error message. Could there be an issue caused by the cylindrical geometry I am using? |
March 28, 2015, 03:00 |
According to the log you have provided the error happens during sqrt call. SyamlalOBrien CdRe method contains bunch of sqrt calls. Also you have mentioned that while using Gidaspov (which on btw?) your case also halts with error. Both models contain pow(Re, 0.687) and if Re is negative, FPE occurs. Why Re is negative? Guess your solution is diverging. And finally as you have said, you are able to run the case on coarse grid, it looks your time step is too large. Do you adjust time step? Though it would be easier if you just attach archive of your system folder (as after adjustTimeStep question, there will be nOuterCorrectors question, convergence criterion question etc). |
March 28, 2015, 18:00 |
Rep Power: 11 |
Thanks for the suggestion. The time step seems to solve the issue.
April 24, 2015, 14:27 |
Hello Everyone
I am also using OF2.3.1 and simulating 2D fluidized bed using solver twoPhaseEulerFOAM. I am facing a similar problem as mentioned above but smaller time step is not working for me. 1) First of all I changed some parameters like diameter of particle, geometry dimension (2D sylinderical geometry), viscosity, Alphamax 0.65, and tried to run the simulation, I got the following error [QUOTE][/#0 Foam::error:rintStack(Foam::Ostream&) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Floating point exception (core dumped) ] Then I thought there might be something wrong with my changed whcih I have made. I tried to run simulation without any change in 2.3.1 tutorial, still I got the following erroe [QUOTE][/#0 Foam::error:rintStack(Foam::Ostream&) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam:perator/<Foam::Vector<double> >(Foam::UList<Foam::Vector<double> > const&, Foam::UList<double> const&) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #4 Foam::interstitialInletVelocityFvPatchVectorField: :updateCoeffs() in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #6 in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 in "/home/waqas/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Floating point exception (core dumped) ] Can you please tell me, what is going wrong and how can I fix this error. I received these errors after very first time step. Regards |
April 24, 2015, 14:44 |
Rep Power: 11 |
Your error log looks different that the one I posted originally. Some more details will be helpful.
Which tutorial case are you trying to run? I'm assuming this is the case you modified (if not, let me know). |
April 24, 2015, 15:13 |
Hello ANacc
Thank you so much for your quick response. I have posted two errors. First was produced with the modified case, and the second error was generated for openfoam default tutorial. Now my problem is resolved. Actually I was making mistake in alpha.air boundary condition. I was using inlet and outlet for alpha.air as fixedValue =0 Anyhow I am simulating 2D fluidized bed for dp=728 micron with k-epsilon model using twoPhaseEulerFoam, this work is for my master thesis. May be I need your help in future if I face any other problem. Thank you Regards |
May 7, 2015, 07:52 |
Hello ANacc
I am using OF2.3.1 for the simulation of fluidized bed: I am facing a problem in mass conservation. WHen I use following command to check the mass flow rate of air and particles at inlet and outlet, it does not conserve. patchIntegrate phi.air inlet patchIntegrate phi.air outlet patchIntegrate phi.particles inlet patchIntegrate phi.particles outlet I am using following boundary condition for 0/alpha.particles/inlet, outlet (fixedValue = uniform 0) in order to make sure zero entrainment of solid particles with air. Also the superficial velocity is too low for entrainment. The above mentioned commands are showing zero mass flow of particles out of the geometry with air. So for air inlet and outlet mass flow should be equal but it is showing almost 5% increase in air mass flow. Have you tried these commands or have any idea about it. Thank you Regards |
openfoam, twophaseeulerfoam |
Sliding mesh for twoPhaseEulerFoam | Lapo | OpenFOAM Programming & Development | 4 | November 25, 2019 14:23 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 08:10 |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 10:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
stratified horizontal two phase flow usinfg twoPhaseEulerFoam | karthik1414 | OpenFOAM | 0 | April 12, 2011 09:57 |
