Turbulence: is it possible to obtain second order quantites, like u'v' ?
Old   April 2, 2015, 06:03
Default Turbulence: is it possible to obtain second order quantites, like u'v' ?
António Pires
Antoniorp is on a distinguished road
Hello everyone,
I have some questions regarding turbulent models with openfoam.
Using first order models like k-epsilon or k-omega SST is it possible to easily obtain second order quantites, like u'v' ? If yes, how is that done? Or the only way to obtain those quantities is through another turbulence model?
Thanks,
António
Antoniorp is offline   Reply With Quote
Old   April 2, 2015, 12:55
Icaro A. Accordi
icaroaccordi is on a distinguished road
No, it is not. They use isotropic turbulence assumption. You need a Reynolds stress model (second closure) to do that. LRR is a example that is already implemented in OpenFoam.
icaroaccordi is offline   Reply With Quote
Old   April 2, 2015, 13:47
António Pires
Thank you for your reply!
Antonio
Old   April 6, 2015, 07:31
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Originally Posted by Antoniorp View Post
Hello everyone,
Thanks,
António
Hi António,
I would say if you don't prefer to use Reynolds Stress Model that can directly get the shear stresses i.e. u'v', so for the turbulence modles like k-epsilon or k-omega SST you can use the simple Boussinesq relation (http://www.cfd-online.com/Wiki/Bouss...ity_assumption) to obtain the quantities like u'v'.
Regards,
Taxalian
taxalian is offline   Reply With Quote
First Order to Higher Order Blending Factor NormalVector FLUENT 4 November 13, 2023 07:06
IS calc. with 2nd order discret. always necessary? Azman FLUENT 2 March 14, 2013 04:28
First order simulation better than second order Torque_Converter CFX 7 January 8, 2013 04:07
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
Turbulence boundary values lego CFX 9 October 25, 2002 11:55
