Need guidance and tips about a fluidized bed reactor gasifier simulation |
April 8, 2015, 16:54 |
César Augusto Corrêa Miguéis
Rep Power: 12 |
Hi everybody! First of all, let me say that I've started to learn how to use OpenFOAM about a month ago, so I've only studied the tutorial cases that are presented in the official guide.
I would like to receive some help on how to setup a case for the simulation of a fluidized bed reactor gasifier. In my study, I'd like to simulate the gasification process of biomass, using an Euler-Lagrange approach. The turbulence moddeling would use LES approach, but I'm still studying this subject to decide about it. The flow is compressible. I'll try to give a brief explanation about the whole case that I want to simulate:
I hope this picture can help a little bit the understanding of the situation: So, I woul appreciate any help or tip anyone can give me. Thanks in advance, and regards from Brasil.
César Miguéis Mechanical Engineer MSc. Student at COPPE/UFRJ |
April 21, 2015, 09:27 |
Rep Power: 12 |
Hello everyone, I tried to setup the bed particles first, but I'm facing a problem.
I defined the initial location of the 4000 bed particles, using the limestonePositions file. This is how the initial configuration looks like: Each particle has 3mm of diameter. When I tried to see how it would be after each particle accomodate itself in the bed, just because of gravity and the collisions between particles/particles and particles/wall, I got this, after a few step: And they seem to disappear after more steps. It seems to me that each particle is invisible to another, but I put the springSliderDashpot model collision for particles! This is the limestoneCloudProperties: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object limestoneCloud1Properties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled true; transient yes; cellValueSourceCorrection on; maxCo 0.3; sourceTerms { schemes { U explicit 1; h explicit 1; radiation explicit 1; } } interpolationSchemes { rho cell; thermo:mu cell; U cellPoint; Cp cell; kappa cell; T cell; G cell; } integrationSchemes { U Euler; T analytical; } } constantProperties { parcelTypeId 2; rho0 1500; T0 1050; Cp0 1300; epsilon0 1; f0 0.5; } subModels { particleForces { sphereDrag; gravity; } injectionModels { model1 { type manualInjection; massTotal 0; parcelBasisType fixed; nParticle 1; SOI 0; positionsFile "limestonePositions"; U0 ( 0 0 0 ); sizeDistribution { type fixedValue; fixedValueDistribution { value 0.003; } } } } dispersionModel none; patchInteractionModel standardWallInteraction; heatTransferModel RanzMarshall; stochasticCollisionModel none; collisionModel pairCollision; pairCollisionCoeffs { maxInteractionDistance 0.003; writeReferredParticleCloud no; pairModel pairSpringSliderDashpot; pairSpringSliderDashpotCoeffs { useEquivalentSize no; alpha 0.5; b 1.5; mu 0.30; cohesionEnergyDensity 0; collisionResolutionSteps 12; }; wallModel wallSpringSliderDashpot; wallSpringSliderDashpotCoeffs { useEquivalentSize no; collisionResolutionSteps 12; youngsModulus 2e9; poissonsRatio 0.3; alpha 0.1; b 1.5; mu 0.3; cohesionEnergyDensity 0; }; } surfaceFilmModel none; radiation on; standardWallInteractionCoeffs { type rebound; e 0.5; mu 0.3; } RanzMarshallCoeffs { BirdCorrection false; } } cloudFunctions {} Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 0) (95 0 0) (0 60 0) (95 60 0) (0 110 0) (95 110 0) (-19.5 600 0) (0 600 0) (95 600 0) (114.5 600 0) (-19.5 1000 0) (0 1000 0) (95 1000 0) (114.5 1000 0) (-19.5 1040 0) (0 1040 0) (95 1040 0) (114.5 1040 0) (-19.5 1100 0) (0 1100 0) (95 1100 0) (114.5 1100 0) (0 0 4) (95 0 4) (0 60 4) (95 60 4) (0 110 4) (95 110 4) (-19.5 600 4) (0 600 4) (95 600 4) (114.5 600 4) (-19.5 1000 4) (0 1000 4) (95 1000 4) (114.5 1000 4) (-19.5 1040 4) (0 1040 4) (95 1040 4) (114.5 1040 4) (-19.5 1100 4) (0 1100 4) (95 1100 4) (114.5 1100 4) ); blocks ( hex (0 1 3 2 22 23 25 24) (10 6 1) simpleGrading (1 1 1) hex (2 3 5 4 24 25 27 26) (10 5 1) simpleGrading (1 1 1) hex (4 5 8 7 26 27 30 29) (10 49 1) simpleGrading (1 1 1) hex (6 7 11 10 28 29 33 32) (2 40 1) simpleGrading (1 1 1) hex (7 8 12 11 29 30 34 33) (10 40 1) simpleGrading (1 1 1) hex (8 9 13 12 30 31 35 34) (2 40 1) simpleGrading (1 1 1) hex (10 11 15 14 32 33 37 36) (2 4 1) simpleGrading (1 1 1) hex (11 12 16 15 33 34 38 37) (10 4 1) simpleGrading (1 1 1) hex (12 13 17 16 34 35 39 38) (2 4 1) simpleGrading (1 1 1) hex (14 15 19 18 36 37 41 40) (2 6 1) simpleGrading (1 1 1) hex (15 16 20 19 37 38 42 41) (10 6 1) simpleGrading (1 1 1) hex (16 17 21 20 38 39 43 42) (2 6 1) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type wall; faces ( (19 18 40 41) (20 19 41 42) (21 20 42 43) ); } bottom { type wall; faces ( (0 1 23 22) ); } walls { type wall; faces ( (0 22 24 2) (4 26 29 7) (6 28 32 10) (10 32 36 14) (14 36 40 18) (1 3 25 23) (3 5 27 25) (5 8 30 27) (9 13 35 31) (17 21 43 39) (6 7 29 28) (8 9 31 30) ); } entrada { type patch; faces ( (2 24 26 4) ); } saida { type patch; faces ( (13 17 39 35) ); } ); mergePatchPairs ( ); // ************************************************************************* //
April 22, 2015, 08:54 |
Rep Power: 12 |
Somebody can help me?
combustion, gasification, lagrangian particles, reactin flow, turbulent flow |
Display Modes | |
