Gas Mixing Measurements
Old   April 21, 2015, 07:48
Default Gas Mixing Measurements
Rogaland
Javell is on a distinguished road
Hi!
I took the liberty of creating a new thread.
My case is pretty straight forward. I have two parallel pipes. The smaller one located inside the bigger one. Eventually the smaller pipe ends and the mixing of nitrogen (bigger pipe) and helium (smaller pipe) begins. The flow rates are controlled by the inlet velocities (1% helium, 99% nitrogen).
What I'm going to investigate is the level of mixing. I've been told that the CoV (Coefficient of Variation = standard deviation / mean) represents how well the mixture has blended.
CoV = 1 means no mixing, while CoV = 0 indicates a perfect mix?
With this being said I think I'm ready to define my problem. As you can see in the code below (functions output in controlDict), the CoV is greater than one. This means that the difference in concentration at a given measurement point is significantly higher or lower than the mean concentration of the cross section at the majority of measurement points? I.e. there is definitely not a uniform mix?
Also, the flow rates given by my initial conditions doesn't seem right either (0.01-0.99). The inlet conditions have been verified several times. I could try changing from a velocity condition to a flow rate condition, although I can't see how this will change anything.
The plane1/2 output is taken from a plane right before the outlet.
the faceObje1/2 output is taken from my patch "outlet".
Any thoughts?
faceSource plane1 output:
    areaAverage(sampledSurface) for He = 0.00162516212296
    areaAverage(sampledSurface) for T = 352.574410291
    areaAverage(sampledSurface) for N2 = 0.998374837877
faceSource plane2 output:
    CoV(sampledSurface) for He = 1.29855814792
    CoV(sampledSurface) for T = 0.00170251695443
    CoV(sampledSurface) for N2 = 0.00211380278868
faceSource faceObj1 output:
    areaAverage(outlet) for He = 0.00158949601069
    areaAverage(outlet) for T = 352.583244014
    areaAverage(outlet) for N2 = 0.998410503989
faceSource faceObj2 output:
    CoV(outlet) for He = 1.31250790071
    CoV(outlet) for T = 0.00168238393736
    CoV(outlet) for N2 = 0.00208954739943
Javell is offline   Reply With Quote
Old   April 22, 2015, 01:20
styleworker is on a distinguished road
Which solver are you using?
styleworker is offline   Reply With Quote
Old   April 22, 2015, 02:15
Rogaland
reactingFoam with reactions turned off.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Gas flow profiles in mixing tank srinivas FLUENT 0 November 8, 2006 04:52
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
