OpenFOAM thermal study in a pipe
Old   May 31, 2015, 10:29
Default OpenFOAM thermal study in a pipe
giuseppe corrado
giusepp93 is on a distinguished road
hello guys,
i'm new to OpenFOAM and i need some help to set up my case. I have to implement a flow in horizontal cylindrical tube in which there is water-based allumina (Al2O3/water) nanofluids (with volume fraction 3%). I made the simple geometry and the mesh with Salome, after that i exported the file in unv format ( with wall inlet and outlet mesh groups). I want to study the heat conductivity and the sedimentation effect in the pipe, so i think i should use the buoyantBoussinesqSimpleFoam solver and so i copied and pasted the file in the hotRoom tutorial folder in order to change the paramether and to do my simulation. So using ideasUnvToFoam command in the terminal i imported my geometry.
Is it the right procedure? Someone can help me???
The simulation is for a study about sedimentation in a flat panel solar thermal collector using nanofluids. I have some doubts about how to change that parameters in 0, constant and system folders.
giusepp93 is offline   Reply With Quote
Old   June 9, 2015, 15:06
giuseppe corrado
Originally Posted by giusepp93 View Post
hello guys,
Nobody know how to set Temperature boundary conditions? i was thinking to use turbolentHeatFluxTemperature
#cylinder, #flow, #heattrasfer, #nanofluids, #pipe
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 03:43
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
which is most referred as an experimental study of pipe with circular orifice? wv1216 Main CFD Forum 1 December 30, 2011 16:34
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Thermal analyse in openfoam, reasonable? suitup OpenFOAM 0 July 13, 2009 06:21
