July 19, 2015, 14:50 |
Mesh sensibility in 2D simulation
Alessandro Del Buono
Rep Power: 10 |
Hi guys,
i did a Urans 2D simulation about Re3900 flow over a circular cylinder; i used a mesh with yplus= 23-28 and i obtain result (in terms of Cd and Cl) near to literature value. Then i proved to use a coarser(-40% number off cells) and a finer(+40% number off cells) mesh, but results are bad! Which could be the reason??? Best Regards |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
airfoil mesh genaration and simulation with a trip on surface issue | rajibroy | Mesh Generation & Pre-Processing | 1 | December 3, 2014 02:04 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Sliding mesh vs MRF in axial turbine simulation | Vito | FLUENT | 3 | December 21, 2011 04:57 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
