October 7, 2015, 06:49 |
refineMesh doubt
miguelangel
Hi, this is my first post.
I want to know how use the refineMesh to refine a 3D model of a diesel nozzle injector only in one direction. I'm trying to include all the geometry in a box using topoSet, but when I use refineMesh, it doesn't work because one cyclic patch has 160 faces and the patch which is next to it has 170. This is the geometry that i'm using And this the topoSetDict actions ( { name c0; type cellSet; action new; source boxToCell; sourceInfo { box (-0.0002645441 -0.0008838835 -0.0006520926) (0.00209388 0.0008838835 0.001411752); } } ); Thanks !! |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 13:44 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
Cannot refineMesh with useHexTopology true ver141 | naoki | OpenFOAM Bugs | 5 | June 11, 2008 04:07 |
