April 12, 2011, 11:43 |
convertion of openfoam .msh file to fluent
kostas
Rep Power: 15 |
How can i convert the .msh file which used by openFOAM and which had made by gmsh mesh generator to FLUENT mesh input file. I have made some meshes in gmsh and i cannot input them to fluent.
April 13, 2011, 09:51 |
Fabio
Rep Power: 16 |
foamMeshToFluent which converts the OpenFOAM
mesh into Fluent format and writes it out as a .msh file. The resulting mesh is written out in a fluentInterface subdirectory of the case directory, i.e.<caseName>/fluentInterface/<caseName>.msh |
April 14, 2011, 03:09 |
aaaaaaaaaaaaaa
Rep Power: 15 |
foamMeshToFluent is a simply converter or part of openfoam? where can i download it from? Can i run it by windows?
April 14, 2011, 04:07 |
Fabio
Rep Power: 16 |
foamMeshToFluent is a simply command in openFoam
December 21, 2015, 12:30 |
foamMeshToFluent
Amr Refay
Hi Panou,
foamMeshToFluent is a command in OpenFOAM that will convert the meshing in OpenFOAM format to be in a meshing in Fluent format and it is a part from OpenFOAM. You have to have OpenFOAM on your Linux system to run the command. You will need extra work on windows to install OpenFOAM and use the foamMeshToFluent command. Thanks, Amr, |
.msh file cann't be by Fluent | nchuche | FLUENT | 1 | June 29, 2010 10:38 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
The format of .msh file for fluent | scubme | FLUENT | 2 | October 18, 2004 22:50 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
