foam-extend-3.1 + probes in rotating frames
Old   January 5, 2015, 18:26
Default foam-extend-3.1 + probes in rotating frames
sirLentschi
lentschi is on a distinguished road
Hello!
I want to use the probes-function in order to record the pressure p at some specific points. In that case, all monitoring points have to rotate with the wall (which is part of a rotating cellZone), so that the relativ position is always the same!
Is there any possibility in this mentioned function to perform that?
Best Regards,
Markus
lentschi is offline   Reply With Quote
Old   January 6, 2015, 07:27
cutter is on a distinguished road
I'm neither using extend, nor rotating systems yet. I want to share an idea though:
Maybe you could use the #codeStream directive (http://www.openfoam.org/version2.0.0...me-control.php) to compute the correct position of the probes at run time.
Good luck!
Cutter
cutter is offline   Reply With Quote
Old   January 4, 2016, 14:18
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Unfortunately #codeStream is not supported in foam-extend yet.
Zeppo is offline   Reply With Quote
Old   January 4, 2016, 15:10
Ali
aligoger is on a distinguished road
You can do it in paraview itself. There is plot over selection time in filter. Before applying plot over selection time, you need to create point or cell selection in paraview. I hope it helps.
aligoger is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
