September 19, 2011, 21:51 |
Dissimilar meshes with chtMultiRegionFoam
Charles McCreary
Rep Power: 15 |
I've been using chtMultiRegionFoam with good success for some time now. To date, all of the cases I've solved have been "consistent" meshes in that the solid/fluid interface patches share the same points. Is there a mechanism in OpenFOAM in which I can use completely different meshes for the solid and the fluid in which no points are shared?
My objective is to have a rather coarse mesh for the solid and a very fine mesh for the surrounding fluid. |
September 21, 2011, 03:03 |
Aram Amouzandeh
Rep Power: 17 |
thats a very good question I d be also interested in! what I m currently trying is to refine the base mesh where later on the individual regions should be placed in order to achieve different mesh sizes in the regions.
aram |
September 21, 2011, 08:34 |
Vesselin Krastev
Rep Power: 20 |
The chtMultiRegionFoam (and chtMultiRegionSimpleFoam as well) solver implemented in the OpenCFD OpenFOAM releases (at least till the 1.7.1 one) needs a consistent mesh at the separation surface between different regions. By the way, I saw recently a presentation from Prof. Jasak in which he explained quite clearly that the GGI (Generic Grid Interface) implemented in the -dev or -ext OpenFOAM releases is (in principle) capable of handling any type of flux exchange between two adiacent non-conformal interfaces: thus, if you are interested in this topic, I can advice you to deeply investigate the capabilities of the OpenFOAM-1.6-ext release (personally I havent't had sufficient time to do it in the last period, so I will not be able to give you any practical further support about this matter).
Regards V. |
September 21, 2011, 15:02 |
MSR CHANDRA MURTHY
Rep Power: 17 |
It must be possible with ggi feature of 1.6-ext. The non-conformal fluid-solid coupled BC need to be conservative and at-least 2nd order accurate to get better results. I think it can work out, if you can write a new BC inheriting the classes of ggi and coupled bc of chtmultiregionfoam. It appears that the present implementation of ggi in 1.6-ext is conservative due to face-cutting method. I think it is possible to implement it.
I have done a similar type work, which takes the nearest 3 points and calculates new face field using inverse distance weight function method. hope this is useful regards, Chandra Murthy |
February 9, 2016, 06:49 |
Peng Liang
Rep Power: 12 |
Could anyone tell me if it is possible to use dynamic mesh refinement in fluid region in chtmultiregionfoam . If yes, could someone tell me how. Bests , Peng |
February 12, 2016, 03:26 |
Rep Power: 10 |
I don't know about dynamic mesh refinement but to answer the original question of this thread.
It is possible to use arbitrary mesh interfaces by using nearestPatchFaceAMI as boundary type between solid and fluid. |
February 12, 2016, 04:07 |
Rep Power: 10 |
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes | philippose | OpenFOAM Meshing & Mesh Conversion | 8 | May 21, 2016 15:44 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
Dynamic Meshes | Cfdtoy | FLUENT | 2 | February 6, 2004 12:14 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 09:22 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
